well you could but its not to good to run the power supply over voltage. you could get away with it for a while on 230 but what is actually at your 220-240 outlet voltage wise? by the way the 3 variations of that set for input voltage have there own SPECIFIC transformers att-226,227 and 228. i mention the actual wall voltages as they vary a lot depending on what part of the country you live in. it was 110 when i was a kid in illinois then went to 115 and when i was in hawaii it was 120 and double those figures for 220-240 connection.it can also dip during the day as usage and line drop go up. i wouldnt run it on 240. you do have a dim bulb tester dont you? that 220-240 stuff can be quite dramatic if the thing has a problem you dont know about.
