Fair points, which is why I have put the tang of the heatsink on the same net as the collector (pin2). Pins 1&3 have their own fills with pin2&heatsink on another larger one. Although the tang on the heatsink I have found isn’t as large as I would like (but am currently limiting my choices to the mouser ‘catalogue’).
In work we use up to 60A devices (used on phase cut dimmers) and have IR camera data showing the leads do conduct significant amounts of heat to the copper, perhaps it’s just the heat of the transistor body but it’s still heat, so why not spread it out if you can?
Your suggestion on using terminal blocks surprises me. I don’t have any experience with wire wrapped connections but have read up on them. Their cold welding to the posts and resistance to oxidisation made me think that terminal blocks are a less than optimal solution. Yes, they make life simpler but a better solution? I wasn’t sure. Thanks, now I feel better using them and have used them on the schematic.
Ferrules? OK, using them on the few connections that use stranded wire makes sense but as most of the wires are solid I don’t see the advantage to use them on those, as hopefully any change of the PSU board is a once in a lifetime event.
The only major item remaining is the transformer. Does anyone have one that they can measure so that I can produce a footprint? I really don’t want to have to remove my amp’s PSU board again just to measure the distance between the pins.
I have attached the Altium files, as is, at the moment (well I would have if the file types were allowed, but they are not - Anyone know if I can link to files in my Google Drive?). When I get a finalised version I will post the project files (in text format so that the schematic can be read into OrCAD), Gerber, XY and BOM info I send to my local PCB manufacturer. That way anyone who wants to make a new Power Supply board can get them made (I deliberately didn’t use SMD devices so that the project is ‘easy’ to construct).
