Rsclj
received this beast for $0.00 was told it doesn't power up...well the initial inspection shows some issues...nothing in the way of blown fuses, (would have been a nice find as a cause for not powering up) but the main filter caps are shot and have leaked...the PS (AWR070) has been hacked upon...some transistors have been replaced and the traces have been royally screwed (on leg of several transistors can be moved thru the board and the trace moves with them) parts for this board were ordered and have arrived so I guess its time to dig in for a total board rebuild. repairing those screwed traces could be interesting, I may have to desolder the wire pins to gain proper access to the foil side of this beast...I will try to unbundle some of the wires to see if I can get a bit more slack...pulling the bad main filters will also give me some more room. thankfully I still have a couple of 100W incandescent bulbs left for the DBT. Thanks to LesE for his extensive component list for this unit, and his PM support already in this process...more to come
