Samsung HL-S6187W dlp tv, an myself not being to bright
Discussion in 'Home Theater & Video' started by jami w., Jul 9, 2018.
  1. jami w.
    jami w. just being me thats all
    3,514
    New hampshire
    i went out earlier today an bought 3 hdmi cables, came back and pulled out the tv stand. hooked it all up
    tv to pioneer reciever, turn on tv the ps3 an stereo switched to tv settings button. no surround sound not even in 2 channel!!
    now remember im still a noob to surround sound,
    from ps3 to hdmi on tv
    tv sound to reciever ( dvd/ld) audio input
    as long as its either hooked to tv/sat- dvd/ld or the other dvd inputs on back an that front button is pushed, i should get surround sound but im not. im sure its something pretty stupid that im not seeing in either thetv settings/reciever settings.
    (please read through the posts)
  2. StimpyWan
    4,403
    Blue Ridge Mountains!
    "from ps3 to hdmi on tv, tv sound to reciever ( dvd/ld) audio input"
    Why hook it up this way? Why not PS3 HDMI to Receiver HDMI out to TV. That's how my old PS3-Pioneer system was connected, and I never had an issue. It played Blu-Ray and multichannel SACD without any problems, with that wiring method.
  3. jami w.
    3,514
    New hampshire
    the gaming hook up on the pioneer is in the front, an its the rca jacks red/white/yellow.
    so i have to hook it up through the tv. theres no gaming port (hdmi) on the back of reciever.
  4. StimpyWan
    4,403
    OK, I'm confused. Is the PS3 your gaming console? The PS3 has HDMI out. Why aren't you using that connection, if so? Why composite video, and L/R analog audio? Even though the rear HDMI inputs aren't labeled as the "Gaming" connection, you can still use HDMI for any source that also uses HDMI. You might have to reassign the input, but the 1017 Manual (once downloaded) describes how.
    GChief and jami w. like this.
  5. JoeESP9
    16,954
    Philadelphia PA
    On many TV's the audio out (coax/optical) will only carry a surround signal from the TV's internal tuner. Any other source connected to the TV even HDMI will result in a two channel only signal. Check the manual for your TV.
    Bill Ferris and the skipper like this.
  6. Aspen
    Aspen Active Member
    365
    London, Ontario
    This.. Use the receiver to due switching and send one HDMI signal from it to the TV.
    jami w. likes this.
  7. jami w.
    3,514
    New hampshire
    that i didnt know ( can use any hdmi outputs on the back) for ps3. ill give it a shot tonight once it cools down for weather.
    StimpyWan likes this.
  8. jami w.
    3,514
    New hampshire
    same reply as i gave stimpy, once the weather cools off a bit later this evening, ill give it a shot
  9. jami w.
    3,514
    New hampshire
    i did warn an tell everyone im still a newbie, when it comes to surround sound. my first ever surround sound reciever was that yamaha 5150. then the marantz sr7000 that went to a good friend of mines son (late 30's).
    an to this beast of a reciever :beerchug:
    i still have no friggin idea of how many surround settings this has!
  10. JoeESP9
    16,954
    Philadelphia PA
    This is what I do. Although in my case it's a pre/pro (Emotiva UMC-200) that does the switching
  11. jami w.
    3,514
    New hampshire
    i have the ps3 hdmi cable plugged into hdmi1
    on back of reciever, an hdmi from reciever
    to tv arc hdmi an just a blank screen.
    not sure if its the tv settings/ or stereo settings. but ill figure it out.
  12. JoeESP9
    16,954
    Philadelphia PA
    The only connection my TV uses is a single HDMI from the pre/pro. My FIOS cable box, Roku and Blu-ray player are connected only to the pre/pro. I also have a five port HDMI switch connected to the pre/pro. My music server laptop PC, main desktop PC, SACD player (for MC SACD's) and PS3 are connected to the switch. I don't bother with ARC as all the audio signals are available via the pre/pro.
    The SACD player is also connected to my stereo preamp via its analog outputs.
  13. jami w.
    3,514
    New hampshire
    how does all that help me? :dunno:
  14. JoeESP9
    16,954
    Philadelphia PA
    To start with, turn off/disable ARC and see if you get a picture.
    Bill Ferris likes this.
  15. jami w.
    3,514
    New hampshire
    no pic still its just annoying, if i had the cash? id call geek squad an say come fix it lol.
  16. jami w.
    3,514
    New hampshire
    dont have to dl the manual as i have all factory paperwork when it was new. an including that little factory warranty card you mail in.
  17. Duane
    Duane AK Member Subscriber
    3,856
    San Diego
    Double check your HDMI cable(s) to ensure that you have them oriented correctly. Most cables have "Source" on one end and "TV" on the other. For trouble shooting purposes, it's sometimes best to keep it simple. Make sure all of your cables work. Use one source and connect each cable directly to the TV to verify they all are good.
  18. JoeESP9
    16,954
    Philadelphia PA
    HDMI cables have the same connector on both ends. They are not directional.
    imral3 likes this.
  19. Duane
    3,856
    San Diego
    I have Monoprice HDMI cables and they are directional.
  20. StimpyWan
    4,403
    Yea, some of the high speed HDMI Monoprice cables are marked as directional. Though, I do wonder if that really matters?
