Sanken STV3H-Y Testing and Installation??
Discussion in 'Exclusively Sansui' started by Juan9568, May 14, 2018.
  1. Juan9568
    Juan9568 Member
    77
    Buenos Aires, Argentina
  2. tnsilver
    tnsilver Super Member
    2,962
    Boston
    In diode test mode with red (+) probe on the anode and black (-) probe on the cathode (yellow dot) you should be reading about 1.4V of forward voltage.
  3. clinic-audio
    2,275
    France
    yes , those components are diodes (some are with 3 diodes in the same package)
  4. Hyperion
    49,282
    Hertfordshire, UK
    Your meter may not have enough test voltage to start them conducting. The diode test range on your meter is expecting one P-N junction to test, an STV3 is 3 junctions, which gives some meters problems. You could try the 'ohms' range but cross check any readings you get with the old diodes before drawing any conclusions from the readings you are getting.
    You could set up a very simple test circuit using a 9V battery (for example) and using a series limiting resistor (- important), and then reading the volt drop across the device when it is conducting.
    dlucy, Goldie99 and tnsilver like this.
  5. Juan9568
    Juan9568 Member
    77
    Still, I don't get any reading. Not even in ohms range...could it be my meter?? I have a cheap one DT830D :(
  6. tnsilver
    2,962
    Boston
    or the battery, or dirty probes, or meter fuse, or wrong probe terminals, or you're just near the south pole in the midst of a solar flare :dunno:
    It's all more likely than all of these diodes gone bad at once.
    Hyperion likes this.
  7. Juan9568
    Juan9568 Member
    77
    haha I mean that maybe I need a pro meter to test these diodes? cause 2 of them are new the other 2 are the original ones but none of them give me a reading. Meter is new (but cheap), everything else is new, black probe in COM, red probe in V/Ohm/mA Fused...fuse is fine too
  8. tnsilver
    2,962
    Boston
    Well, John gave you a pretty good reason in #4 why this may not work. I don't think you need a pro meter, but if the battery is good you definitely need a better meter. If it's any consolation, I've purchased dozens of Sanken STV-3HY's from the same German seller. They all came neat and tidy in their blue cardboard boxes and the amount I found bad was a flat zero. In fact... I never found a stock one that went bad either.
    Goldie99 likes this.
  9. tarior
    tarior Dirty pool, old man? Subscriber
    6,579
    Kelso, Washington
    What was wrong with the old ones?
  10. Juan9568
    Juan9568 Member
    77
  11. tarior
    6,579
    Kelso, Washington
    Too bad you aren't in the US, I would ask you to send me the old ones. They very rarely ever fail.
  12. kevzep
    STV3 diodes are not a failure point, I have never actually seen one fail all all the years I have been around electronics...
    tarior likes this.
  13. tarior
    6,579
    Kelso, Washington
    Neither have I. Even on units with the amp torched all the way back to the VAS stage.
  14. Overundr1
    2,514
    Mississippi
    Much more common to find one miss-handled with a broken lead
    ghazzer, AUD101, tarior and 1 other person like this.
  15. sregor
    3,648
    Mass
    Best way to test (IMO) would be to get a 9 volt battery and an 8.2K resistor, and measure voltage drop. Should be 9 volts in reverse direction (no current) and 1.3 (or more based on my reading, not my experience) in the forward direction. Meter should be in volts measuring mode. I've never had occasion to change these. We used to keep them as replacement for the little bead 3 diode bias diodes. YMMV
  16. ghazzer
    ghazzer Senior Member Subscriber
    3,059
    Sykesville, MD
    dlucy likes this.
  17. kevzep
    Just use your meter guys, its very simple, diode test function, the STV3 has a forward voltage of about 1.4V....Easy, job done.
