SANSUI 1000X refreshing
Discussion in 'Exclusively Sansui' started by Mike244, Sep 15, 2016.
  1. Mike244
    Mike244 New Member
    31
    Hi all!
    I have a heavy baby - 1000X reciever ;)
    Few days ago start recap and refresh some parts - rectifier boards etc...
    Also replace first transistor (2SC458) on amp board on new Toshiba 2SC2240. Old 2sc458 often have internal corrosion inside...
    Make soldering work on amp board - solder each point on the board, I guess you knew why... ;)
    Starting work on rectifier board -use ultra-fast SF34 diodes (3A 125V) :
  2. Mike244
    Mike244 New Member
    31
    First stage finished ;)
      File size:
      91.3 KB
      25
      File size:
      43.3 KB
      24
      File size:
      84.6 KB
      25
      File size:
      77.1 KB
      23
      File size:
      97.3 KB
      23
      File size:
      103.8 KB
      24
  3. Hyperion
    43,026
    Hertfordshire, UK
    Definitely looking better :thumbsup: - thanks for posting the pictures.
  4. Mike244
    Mike244 New Member
    31
    Thanks John! I think same, I did not like it (yellow-red ring on the right cap - thinking it was electrolyte leaking):
  5. OhioMan
    OhioMan New Member
    1
    could it be possible that you could get photos of the tuner board located right behind the volume control on the 1000x I was a dummy and took out the 1uF caps figuring they also would have the + and - marked on the board like the rest did.. NOPE now i dont have a clue which way they go and hate popping quality caps making a guess.. or even worse..
