Sansui 1000x restoration - Suzuki cap replacement
Discussion in 'Exclusively Sansui' started by toneriderMUC, Sep 9, 2018.
  1. toneriderMUC
    toneriderMUC Active Member
    111
    Munich, Germany
    My newly acquired 1000x needs a recap and restoration. I am currently making a parts list for mouser. I will also replace all 2SC458LG transistors, but I was very surprised to find SUZUKI (oil?) caps in the 1000x. I always thought their use was restricted to tube equipment back then.
    on power block(!):
    0.0047uf / 600V oil
    other positions in between boards:
    0,033 / 600V oil
    0,0047 / 600V oil
    0,068 / 400V oil
    I now wonder what might be a suitable replacement. They can be found in a couple of places and I am not sure, if I can just replace them with any decent audio polypropylene...
    Has anyone experiences with these?
  2. Hyperion
    49,244
    Hertfordshire, UK
    You wouldn't want a Polypropylene there (C058) - you need an X-Y rated film capacitor of at least 275VAC rating, and the same with C057.
    Two more in the PSU have voltage ratings, so you'll need to observe those. I couldn't see too many other positions where Oil capacitors might have been used - but then I am only looking at the schematic. ;)
  3. toneriderMUC
    111
    Munich, Germany
    I found Illinois MPW series ( Mouser 472MPW400K ). Datasheet outlines them to use in power amp applications - should they do the job?
  4. Hyperion
    49,244
    Hertfordshire, UK
  5. toneriderMUC
    111
    Munich, Germany
  6. Hyperion
    49,244
    Hertfordshire, UK
    Tell me the circuit references like 'Cxxx' and I will advise - as you can appreciate I can't see which ones are currently Suzuki oils. :)
  7. toneriderMUC
    111
    Munich, Germany
    John, you are the best!!! :)
    Its those:
    C057,
    C058,
    C059,
    C060,
    C061,
    C062,
    Service Manual page 29, 30. Page 30 has photographs with their position.
    C001 is the the 0,0047 / 600V oil cap in power position mentioned before. Its on board F1251.
  8. Hyperion
    49,244
    Hertfordshire, UK
    C057, https://www.mouser.co.uk/ProductDetail/Cornell-Dubilier-CDE/158X333?qs=0r35cIPu56EgjTKc75ZGMg==
    C058, https://www.mouser.co.uk/ProductDetail/Cornell-Dubilier-CDE/DPPM20D47K-F?qs=sGAEpiMZZMv1cc3ydrPrF7KrP8luoaaUlei1V1rcn9w=
    C059, https://www.mouser.co.uk/ProductDetail/WIMA/MKP4F026803C00JSSD?qs=sGAEpiMZZMv1cc3ydrPrFwgzP98AO9idgumyry699Tg=
    C060, https://www.mouser.co.uk/ProductDetail/WIMA/MKP4F026803C00JSSD?qs=sGAEpiMZZMv1cc3ydrPrFwgzP98AO9idgumyry699Tg=
    C061, can see on picture - but not on schematic.
    C062, can see on picture - but not on schematic.
    C061 & C062
    Please can you tell me the value and voltage of these - and if you can advise where they are connected to, like - Board number // Pin number // connected to:-'other component reference' - anything that helps me know what they are connected to and thus what there purpose is. :)
  9. toneriderMUC
    111
    Munich, Germany
    This is how they look like in my schematic, its another two 0,0047/600:
    They connect parts of the voltage selecter on the back of the amplifier. The selector consists of two seperate plugs and C061 and C062 seem to connect plug 1 and plug 2.
    My unit interestingly only has one of them! I wonder if the second one has been removed in the past.
    C001 is another 0,0047 / 600V oil cap in power position mentioned before. Its on board F1251.
  10. Hyperion
    49,244
    Hertfordshire, UK
  11. Hyperion
    49,244
    Hertfordshire, UK
  12. toneriderMUC
    111
    Munich, Germany
  13. Hyperion
    49,244
    Hertfordshire, UK
    You are welcome. ;)
  14. toneriderMUC
    111
    Munich, Germany
    John, I am currently trying to collect the parts you selected for these positions. One postion is not clear:
    C058 needs to be 0,0047/600. The part/series you selected is unfortunately not produced in 0,0047uf value and does not seem to support the voltage.
    It would be really cool if you could have a quick look at that.. :bowdown:
  15. Hyperion
    49,244
    Hertfordshire, UK
    It does actually, the capacitor I selected is 'AC Rated' at 275V, - meaning that it is good for at least 3 times that rating (maybe even 4-5 times) for applied DC voltages. ;)
  16. toneriderMUC
    111
    Munich, Germany
    Oh!
    But still, that series is not available at 0,0047uf, so I cant take those :-(
  17. Hyperion
    49,244
    Hertfordshire, UK
  18. toneriderMUC
    111
    Munich, Germany
