Sansui 3000 main caps wired in backwards from factory
Discussion in 'Exclusively Sansui' started by kwayde, Feb 6, 2018.
  1. kwayde
    kwayde New Member
    22
    mid Wisc
    I'm in the process of changing the electrolytic caps in my friend's Sansui 3000. I'm changing out the main caps, C09, C10, C11, & C12 first. I pull C12 first, replace it exactly how it was wired up from the factory, then check the schematic to be sure it's correct. Turns out the receiver has C11 & C12 wired in backwards according to the schematic. I checked C09 & C10 to see about them, and they're in correctly. Having a hard time understanding how the factory could let something like this slip through. I listened to the unit before I started any work on it, and the unit seemed to be fine, other than it sounding tinny with a lack of bass.
    Anybody else come across anything like this? Don't know whether to leave it as is, or wire them up according to the schematic.
    https://www.hifiengine.com/manual_library/sansui/3000.shtml
  2. petehall347
    28,247
    uk.. the middle bit
    they would have blown the main fuse in backwards .
    tnsilver likes this.
  3. Robisme
    11,847
    Martinez California
    Put them back in the way you found them. Sansui service manuals and schematics have been known to have mistakes in them from time to time.:D
    Rob
    Bill Ferris likes this.
  4. petehall347
    28,247
    uk.. the middle bit
    hi-fi engine schematic shows them correct way around ..just look where they connect to bridge rectifiers
    Hyperion likes this.
  5. sregor
    3,646
    Mass
    I would bring it up slowly on a variac, and make sure the + and - voltages are correct. )I'm surprised they haven't gone, and would be very leery of firing it up full power until I have a better feel for what's happening.) My 2 cents....
  6. kwayde
    kwayde New Member
    22
    mid Wisc
    Nope, didn't happen. Fuses are good.
  7. kwayde
    kwayde New Member
    22
    mid Wisc
    The schematic shows them in correct, but C11 & C12 are wired in backwards. The blue lead from the transformer is soldered to the negative lead on C12. On the neighboring bridge, the yellow lead from the transformer is soldered to the positive lead of C10. All of the leads are on the wrong terminals on C12 & C11.
  8. kwayde
    kwayde New Member
    22
    mid Wisc
    Don't have a variac. I turned it on to listen to it before I started to work on it to get an idea of how it sounded. Other than it sounding tinny with a lack of bass, I really didn't pay much attention to anything else. Since the identical circuit next to it is wired correctly, I'm thinking I should wire up the one that is wired wrong correctly to see what happens. Will have to check with my friend when I see him tomorrow to see how he feels about this since it belongs to him.
  9. kwayde
    kwayde New Member
    22
    mid Wisc
    I thought about doing that, but it just gets on my nerves. The circuit next to it is identical and the caps are all wired correctly, so I'm thinking this circuit should be wired the same. I have someone else looking at this too. Haven't heard from him yet.
  10. restorer-john
    restorer-john Addicted Member
    6,623
    Australia
    It's more likely that the silk screening on the two caps is back to front and the has thrown you. The caps would definitely have vented and exploded decades ago if they were indeed wired incorrectly.
    Also, check out the service bulletin for that unit- 1000uF non-polar caps on the output.
    Bill Ferris and Hyperion like this.
  11. kwayde
    kwayde New Member
    22
    mid Wisc
    What are the odds that two improperly silk screened caps would end up next to one another in the same circuit, same amp? Also, the owner doesn't want to put a lot of money into this, so instead of doing the service bulletin fix I just fused the speakers.
  12. petehall347
    28,247
    uk.. the middle bit
    pcb silk screening is often wrong
  13. sregor
    3,646
    Mass
    Quick check - One of the collectors of the output transistors goes directly to the + supply Through fuse), and can be easily verified with your meter. The emitter of the other one on that channel connects to the - supply through a low (less than 1/2 ohm) resistor (also through a fuse) and can be checked, but not as easily. (but not that hard)
    Bill Ferris and kwayde like this.
  14. kwayde
    kwayde New Member
    22
    mid Wisc
    These caps are not mounted on a pcb.
  15. kwayde
    kwayde New Member
    22
    mid Wisc
  16. kwayde
    kwayde New Member
    22
    mid Wisc
    What I've decided to do is to connect the new cap the way the bad one was installed, which is backwards. Then I'm going to check voltages. I may possibly have time tomorrow to do this.
  17. The Fuxtor
    The Fuxtor AK Subscriber Subscriber
    2,929
    Calgary, Alberta
  18. Dave_1962
    Dave_1962 Lunatic Member
    19,462
    Ontario, Canada
  19. Hyperion
    49,210
    Hertfordshire, UK
  20. dr*audio
    18,842
    Cleveland, Ohio
    Put the original caps back in wired as you found them, THEN take your voltage readings. If you get this wrong with the new caps you will destroy them. Quickly.
    tnsilver, Bill Ferris and Hyperion like this.
