smokinone
I did the skippy mod to the original 1040 boards, and replaced all the electrolytic caps. Also did the 4 2200 caps, ripple board and protector board.
Here is what I've done pretty much
http://audiokarma.org/forums/index.php?threads/sansui-5000a-bulb-replacement.742707/
I also replaced all the output 118's with new transistors.
I get 80V at the fuse holders and was able to set the bias @23ma.
The problem now is I have no output from any input to the speakers it seems. If I touch the TR802 on either 1040 board I get the hum and noise from the speakers and it goes up or down with the volume. It also gets very warm to the touch.
I don't know if I'm just not getting the signal through the board all the way at the input of the boards or what. I'm not sure where to start to check. I do get a 38V reading at the base and emitter of TR803 on both boards with 80V on the collector. TR804 is about the same with 36V on the base and emitter. Those are the 2 transistors changed out with skippy mod.
It's not blowing any fuses so I assume there are no shorts. I did get a little arching at the fuse holders when setting the bias when attaching the leads, but I think that would be normal since I would be completing the circuit when inserting the meter.
Whatever the issue it seems to be equal on both boards.
I am getting the FM STEREO light lit up as well while testing. And I did hook up a turntable with the same results of no output to the speakers? or input to the amp boards?
Anyone with ideas? I'd sure appreciate it. I have limited knowledge, but have willingness to learn and try.
Thanks
Thanks
