Sansui 771 Signal meter bulb
Discussion in 'Exclusively Sansui' started by summitradio, Oct 10, 2018.
  1. summitradio
    summitradio New Member
    8
    Looking for the teeny tiny bulbs that light the signal meter needle.
    Any leads?
    Thanks
  2. milo63
    milo63 “Talent is a pursued interest." Bob Ross Subscriber
    361
    Everett, WA
    I bought some 8V 3mm LED bulbs online for my 881 meters. To be honest the 3mm LEDs won't work with the plastic "sockets" so you just end up adding heat shrink to keep them in position.
    3mm or 4mm 8V, either will work. eBay seller projectblk86 has been a great help.
  3. summitradio
    8
    Thanks I ordered the led set.
    milo63 likes this.
  4. LBPete
    11,682
    Long Beach, CA
    Before going through the trouble of changing that bulb, be sure that the old bulb has power when the function switch is in the AM or FM position. I'm pretty sure the 771 switches that pointer off when in Phono, tape or aux. If the AM/FM contacts on the function switch are dirty, that could keep the bulb from lighting.
    - Pete
  5. summitradio
    8
    Thanks Pete Ill check again. Has anyone removed the signal meter? Mine has a bunch of dust on the bottom of it.
  6. LBPete
    11,682
    Long Beach, CA
    Sansui typically used a really strong double sided tape to hold them in place. They are very difficult to remove without damaging them.
    - Pete
  7. milo63
    361
    Everett, WA
    On my 881 the back is held on with clear tape, just slice at the seam and with a little love you can work it loose.
    I tried taking off the dial glass but there seemed to be another glass over the meter.
    YMMV
  8. summitradio
    8
    So I took apart the signal meter. The plastic backing plate where the meter is mounted is glued to the metal box that is mounted to the front plate. Careful prying with a knife freed the meter and allowed me to clean the meter and inside the glass and box. I await the LED lamps I ordered to come in before re-assembly.
