I found my Eight about a month ago at a local thrift store for $35
It had a note on it that said for parts or major overhaul. No cord but lucked out again when I found a cord hanging on the wall that fit perfectly. It powered up at the store so I was pretty hopeful it would work.
It's a 72 relay model.
At first it had just a little sound at very high volume but after a can of dexoit it started working pretty good. It started dropping one channel after a couple weeks so I sprayed some more. I took the covers off and got in there pretty good.
Thought it was finally fixed but then it started getting worse. Started dropping a channel again. Playing with the volume or turning the power on and off would usually bring it back . Problems is it now also crackles a lot and trips the relay.
This is my first vintage receiver so I still have a lot to learn. I read you can rule out the relay by plugging into the main out with your phone or ipod and switch the speakers to a+c. When I tried that it played perfectly on both speakers so I assume the speaker relay is not the problem. As soon as I switched back to speaker A it cut out and crackled and tripped the relay again. I also tried it on speaker B with the same results.
Not really sure where to go from here. Clean the pots and switches more is my only guess. I have a digital multi meter but I am complete novice using that too. I'm certainly willing to learn and take things apart but don't want to make it worse.
There's a shop very close to my house but I try to always fix things myself. After reading many posts it would seem to be even better to find an ak forum Sansui expert to get it right. Not sure how to find someone but hopefully I can get it going myself.
Thanks for any advice you might have.
