sansui 8000 blowing lights
Discussion in 'Exclusively Sansui' started by maclvrbr, Nov 10, 2017.
  1. maclvrbr
    maclvrbr Super Member
    1,262
    recently acquired and it needed all 4 dial- meter lights. Looked great after a week 1 went out. I replaced that one a week later 3 of them went out. Any ideas? 6volt 250 ma.
  2. Robisme
    11,469
    Martinez California
    Supposed to be 8 volt 300ma lamps. 6 volt lamps wont last.
    Rob
  3. maclvrbr
    1,262
    My mistake I rechecked my stash and they are 8v 300ma I used to replace with. I checked the SM and it suggest the original was 8v, ideas and thanks
  4. w1jim
    w1jim I can fix it but good... Subscriber
    7,278
    Boston western 'burbs
    Measure the actual voltage at the lamps.
  5. maclvrbr
    1,262
    will do and thanks
  6. maclvrbr
    1,262
    I am getting 9.5 ac volts at the 2.5 amp fuse feeding the lamps
  7. LBPete
    11,120
    Long Beach, CA
    Is this a G-8000? If so, the lamp voltage feed should be 7.5v AC, 9.5V AC is a bit troubling. Where are you located? Is the input voltage selector set correctly? Do you have unusually high line voltage in your house?
    Please post the serial number for the database. Click on the link in my signature block.
    - Pete
  8. Robisme
    11,469
    Martinez California
    What Pete said.
    If all that is fine, you may have to go to 12 volt lamps, if you can find some.
    Rob
  9. LBPete
    11,120
    Long Beach, CA
    NO, don't just go to higher voltage lamps! If that transformer output is high, it's likely all of them are high. If my first suggestions don't turn anything up, you need to check all the transformer output. The dial lamp bulbs may be the canary in the coal mine.
    - Pete
  10. maclvrbr
    1,262
    The input selector is correct. at 120v and does have the option for 220v. I do not have an unusually high voltage in my area. Central alabama. Ideas? thanks
  11. LBPete
    11,120
    Long Beach, CA
    You need to check the voltage of all of the transformer taps. Measure the AC voltage at all of the fuses on the power supply board F-2807. You need to determine if just the lamp supply is high or are other transformer output voltages high. This is a G-8000 right?
    - Pete
    slimecity likes this.
  12. maclvrbr
    1,262
    It is a G801 I thought it was the same receiver. It does have a multi voltage selector and confirmed it to be in 120v. Will do on the voltage check
  13. Robisme
    11,469
    Martinez California
    The dial lamp power comes directly from a secondary winding of the transformer. If the input voltage is correct, there is not much you can do.
    Follow Pete's advise though.
    Rob
  14. w1jim
    7,278
  15. maclvrbr
    1,262
    I checked the fuse voltage as before ACV is 9.5 at F-03, F-02 and F-01 are 55.5 ACV. That voltage is taken with only 1 of the 4 lamps working at this time the other 3 were blown.
  16. maclvrbr
    1,262
    The lamps are round with leads out of 1 end but thanks
  17. w1jim
    7,278
    Oops, all this talk of fuses somehow I incorrectly thought they were fuse bulbs.
    You could always put in a simple voltage regulator or voltage divider to drop the bulb voltage.
  18. maclvrbr
    1,262
    How can I do that very interesting
  19. w1jim
    7,278
  20. maclvrbr
    1,262
    Dwojo said his long lasting 8v lamps work up to 14 acv. Thanks
