Mico
Well-Known Member
Got this Sansui in June but did not have time too look closer into it. Selector switch was/ is obviously messed up
and FM positions are not quite up to the sniff. FM Auto setting does not work but Fm Dolby position seems to be fine. All lights were off except power meters but thanks to the old post I have found here I resolved that issue (image attached). Now the remaining issue is that none of the function indicators are working. I looked into small rice bulbs and they all seem fine, also it would be a bit too much that all were burned. Is there any well known trouble spot for this problem or I should just forget about it?
Traces behind the Selector are really messed, can not understand how could this happen...
