Samiam7364
New Member
I recently purchased a Sansui 9090 in very good condition. The receiver has been sitting for a good amount of time and it needed a good cleaning but now it really looks amazing inside and out. The first time I turned the receiver on the power meters lit up but I had no dial lights. I did some research and found out that this is a common problem and perform a modification that was recommended and now the dial lights work the way they should. The one thing that I haven't been able to correct is the tuner meter will not go dead center. When the unit is in the axillary mode the meter stays off to the left out of the center. When I tune in FM stations it stays to the left even when the signal meter is reading 4 or above. I am receiving stereo broadcast because the stereo lights up and I can confirm that the stereo does work. This has been a perplexing problem because I would like for the receiver to be right. I feel it might have something to do with the voltages perhaps it's not receiving enough. I'm not a technician by any means and this is why I'm reaching out I would appreciate any help anyone could give me in this matter thank you so much for your time.
