Hello,
I've got a lovely 9090db I'm working on that is showing some odd signs I'm hoping someone has dealt with before.
To start, the unit had no output in the left channel, I found 2 defective output transistors and 1 bad transistor on F-2624 (TR05). It's worth noting I tested all transistors on the left channel (and compared them to right channel readings), most out of circuit (only removed one of the transistors attached to heatsink).
Powering up on a DBT (100w bulb), the light goes bright but quickly dims and comes out of protection, but after 3-4 seconds it kicks back in to protection and the light glows bright again, then it cycles continuously like this in and out of protection. It does this consistently if left on (although I've never left it on for more than 30 seconds like this).
I monitored voltage at points 40 and 41 on F-2656 prior to the protection relay and sure enough, both channels show huge swings of voltage right as it kicks into protection (up to 1.4-5 volts DC, monitoring both at the same time with two meters).
Interestingly enough, if I disconnect the left channel from the protection board, the unit functions perfectly. It kicks (and remains) out of protection and DC offset and bias all measure within spec on both channels.
So would the problem be somewhere on the protection board? Or F-2624?
And because I know you'll ask F-2624 was fully rebuilt before I had it, all fusible resistors were replaced and measure within spec, new capacitors, DC trim pots (the bias pots work perfectly). Here is a picture of both sides of the board if you care to see it.
Thanks so much in advance for any help, what a great community Audiokarma has become!
