danrclem
Super Member
I bought a 9090db a couple days ago that wouldn't come out of protection. The guy that I bought it from said that it had been in storage for years and was working before but when he tried to turn it on after taking it out of storage it wouldn't come out of protection.
After some searching I found that the protection board (2657) has two resistors (R13 and R14) that if bad won't let it come out of protection. I also read that if you take the fuses out and that is the problem that it will come out of protection. I didn't unhook these resistors but both of them read open. I took the fuses out and it came out of protection so I guess I found my problem and hopefully there aren't others. My dbt went dim very quick. So far so good.
The service manual says that they are 4.7 ohm 1/2 watt fused resistors. The colors don't look like 4.7 ohm colors to me but maybe they got hot and that changed the color. Now for my questions. Is a fused resistor a special kind of resistor that I have to buy or just a normal resistor that is used as a fuse? I'm thinking that's it's a regular resistor but I just want to make sure. Is a metal film ok for this application? Assuming that this fixes it should I bring it up slowly with a variac and using a dbt or just leave it on the dbt for awhile to make sure nothing goes haywire.
Thanks, Danny
Thanks, Danny
