Sansui 990 receiver protector flashing red.
Discussion in 'Exclusively Sansui' started by tonyanderson, Nov 3, 2017.
  1. tonyanderson
    tonyanderson New Member
    10
    Help with my Sansui 990 receiver. Been sitting idle 25 years. Plulled it out powered up and protector flashes red. Someone told me to pull driver board and check fuseable resistors. Pulled the driver board out and powered up red red green came out of protection mode. Thought I was on to something. Checked the fuseable resistors and all five have no open circuits. What else can I check.
  2. tnsilver
    tnsilver AK Subscriber Subscriber
    2,859
    Boston
    You should probably do these tests using a dim bulb tester. It's a lifesaver so look it up (DBT) and build one if you don't have one.
    Those fusibles should be in their spec'd resistance value. Not open is not enough. The protection circuit does it's work to eliminate
    too much DC current from reaching the speakers, so you should really follow the DC offset adjustment procedure in the manual.
    While at it, the bias current adjustment routine too.
  3. avionic
    38,089
    Fort Dodge, Iowa
    Was it working 25 years ago. Before it was put in storage ?
  4. avionic
    38,089
    Fort Dodge, Iowa
    As tnsilver said. Check DC offset. You might have a shorted output... DC offset check will point to the next step in T-shooting your suiy.
  5. tonyanderson
    10
    Must have taken it out of service for a reason. Been stored 25 years But can't remember. Haven't tested output nor am sure I can with the ? With the driver board removed to keep from going in protection mode. Will recheck the fuseables to see if they are in spec.
  6. The Fuxtor
    The Fuxtor AK Subscriber Subscriber
    2,271
    Calgary, Alberta
    Nice unit! My bet are out of spec fusibles on that driver board.
  7. avionic
    38,089
    Fort Dodge, Iowa
    No you can't.
  8. avionic
    38,089
    Fort Dodge, Iowa
    Allow me to clarify -- Shorted output transistor(s)--
  9. avionic
    38,089
    Fort Dodge, Iowa
    Be able to tell real quick if you have rail voltage present when you check the DC offset.
  10. LBPete
    11,120
    Long Beach, CA
    tonyanderson, welcome to AudioKarma, Exclusively Sansui Forum. Odds are, all that is needed to get it out of protection is to replace those fuseable resistors. The classic failure mode of those resistors is exactly what has happened with this receiver. If it was in storage for 25 years, all the capacitors have lost their charge. The start up surge that occurs when first turned on to charge all those caps after long storage can cause the 40 year old fuseable resistors to go open. Start by replacing them with 1/2 watt metal film resistors. Then we can talk about cleaning all the controls.
    While you have it out, please post the serial number for the database. Click on the link in my signature block.
    - Pete
  11. eiraved
    eiraved AK Subscriber Subscriber
    1,741
    Antelope Valley, CA
  12. kevzep
    What LBPete said!! ^^^^^
  13. tonyanderson
    10
    Ordered 10 resistors from Digakey didn't have the foil ones in stock so ordered the carbon ones. Hope that's ok. 2 10 ohm 1\2 w. 2 22 ohm 1\2 w 2 390 ohm 1\2 w and 4 4.7 ohm 1\2 w. Now we wait. Thanks LBPete.
  14. kevzep
    Metal film is what you should be using, not carbon comp although they will work.
    I find it hard to believe Digikey didn't have metal film resistors???
  15. tonyanderson
    10
    Might have been looking at metal foil ?
  16. tonyanderson
    10
    Will I have to check the DC volts and adjust bias on VR-1 Tru 4 ?
  17. tonyanderson
    10
  18. The Fuxtor
    2,271
    Calgary, Alberta
    The resistors should be labelled "flameproof"
  19. tonyanderson
    10
    Went back to Digikey and ordered the flame proof Vishay BC metal flim resistors. They were there just didn't see them the first time Thanks all.
  20. tonyanderson
    10
    Replaced 10 fuseable resistors reinstalled driver board No go still flashing red. Pulled the driver board back out and checked as much as I could and noted at least 7 resistors with open links. ( not fuseable ones )Now what to do ? Do you guys think a driver transistor shorted out taking the resistors with it ? Do I just send the driver board in to get a recap of the driver board ? Or send the whole receiver in for recap/restore 575 plus shipping both ways.
