I possess a Sansui AU-101 amplifier, which I like quite much. Starting a few years ago, the right channel of the phono input began to make incidentally an annoying crackling kind of noise. It wasn't constant, but still very present and disturbing. Some wiggling with the RCA-connector sometimes seemed to temporarily decrease the noise.
Now, since a few months, the right phono channel has stopped working at all. Wiggling the connector doesn't help anymore.
Some things I tried/observed:
- Switching right and left RCA-connectors left the issue at the right channel. The problem is thus not in the turntable.
- I measured the connections with a multimeter. There is no break in the (beginning of the) circuit. I measured from the RCA-cable up unto the soldering on the PCB
- There are no problems with the other inputs. Aux, tuner, tape al work fine on both channels. So the problem must be somewhere in the beginning of the right phono circuit.
I hope you have any ideas/pointers as to where the problem may lie. Thanks in advance!
