Johnny JJ
New Member
I have an AU-11000 that I recently acquired. The power supply boards (F-2582 & F-2568) had some fried components that needed replacing. I replaced all the electrolytic caps, diodes and almost all the transistors.
Upon power up the protection works properly and the main amp works but running through the preamp there is no sound. I've also set the bias and offset.
The feed from F-2582 to F-2568 measures 68.9V at terminal 01 and 69.6V at terminal 04.
So I'm assuming F-2582 is ok and focusing on F-2568. The problem is the pre-amp boards are not getting sufficient voltage.
The B+ and B- output from F-2568 read +2.0V on terminal 08 and -2.2V on terminal 05 and 0V on terminal 06. Isolated from downstream they measure 0V on terminal 08 and -4.5V on terminal 05 and -2.0V on terminal 06. I've checked all the resistors, solder points, transistor pin matching, diode biasing and everything seems in order. I'm starting to question my substitutions, especially for the transistors. These are the replacement parts I used:
TR01 (2SD356) = MJE15032G
TR02 (2SB526) = MJE15033G
TR03, TR05, TR08, TR09 (2SC1313) = KSC1815YTA
TR04, TR06 (2SA726) = KSA992FBU
TR07 (2SA733) = KSA733CGBU
TR10 (2SC1364) = KSC2690AYSTU
ZD01. ZD02 (RD39EB) = BZX85C3V9 update: **wrong sub(3.9V)**
ZD03 (RD10EB) = BZX85C10
D01 (1N60) = 1N4148TA
D02, D03, D04 (1S953) = 1N4148
D06 (SV02) = Did not replace, but tests ok
I'm hoping someone can see something that I don't or recommend a solution.
