sansui au 2000 power supply voltage change over
Discussion in 'Exclusively Sansui' started by petehall347, Nov 9, 2018.
  1. vic
    vic Active Member
    202
    I have a multimeter
  2. Robisme
    11,851
    Martinez California
    Does the voltage tag on the back show it can be set to multiple voltages?
    Rob
  3. vic
    vic Active Member
    202
    yes got it going all inputs work except phono?
  4. petehall347
    28,253
    uk.. the middle bit
    best check power supply to the phono section .
  5. vic
    vic Active Member
    202
    how to do this
  6. petehall347
    28,253
    uk.. the middle bit
    good question . will look at schematic now .
  7. petehall347
    28,253
    uk.. the middle bit
    f-2501
    pin 48 should be -35v
    pin 47 should be +35
    both with respect to pin 49 . black meter probe goes here .
  8. vic
    vic Active Member
    202
    ok thanks this board is tucked in I need to remove the whole front to get to it this amp is so hard to work on
  9. petehall347
    28,253
    uk.. the middle bit
    best first deoxit the switches .. if already done do it again ..
  10. vic
    vic Active Member
    202
    ok will do that thanks
  11. vic
    vic Active Member
    202
    Pete I did it and guess what I hear my records sounds awesome. I sprayed the shit out of all switches even the f-2051 circuit board.
    Thanks again, your a legend!!!
  12. petehall347
    28,253
    uk.. the middle bit
    well done :thumbsup:
    Hyperion likes this.
  13. Hyperion
    49,230
    Hertfordshire, UK
    And to you too Pete :thumbsup:
  14. vic
    vic Active Member
    202
    hi, I noticed on the power F-2511 protector board there are 2 plug in points No.24 and 25 that have been d/c and someone has blocked them so you cant plug them in.
    Can you tell me why this has been done and should I remove this and plug them back in? Pic attached.
    thanks
  15. petehall347
    28,253
    uk.. the middle bit
    is there a free manual for the 2000 .. i am still looking at the 20000 manual that has protect board marked as f-2498 .
  16. petehall347
    28,253
    uk.. the middle bit
    where do those blue and white wires lead to ?
  17. vic
    vic Active Member
    202
    they go to the transistor board where the heat sink is
  18. vic
    vic Active Member
    202
    the 2498 is a filter board
  19. petehall347
    28,253
    uk.. the middle bit
    2511 is power on relay according to this manual ..
  20. petehall347
    28,253
    uk.. the middle bit
    sorry for poor resolution .. but its centre left
