ok but can u help with problemyou dont really want to plug in anything with a higher output than a turntable into a phono input - you could cause some damage.
yes when I turn the volume up you can hear a faint sound kind of like a transistor radio. I connected the turntable to the tape input and I get a sound.Have you tried connecting a turntable to the phono inputs, so its input is correctly terminated..
I moved the pickup load switch up and down but I don't know where this sensitivity switch in the front is?Phono one - pickup load switch at the back, sensitivity switch in the front- did you try adjusting?
Not familiar with the AU20K, if you can hear radio, is there anything else near by or, connected to the AU20K that can be powered down ,disconnected, moved away. Can you hear the same via the headphone socket, with nothing connected to the au20K. Presuming you have already done this.
yes but no changeDid you try toggling between phono 1 and phono 2 to see if that makes any difference? Did you try both phono inputs in the back as well?
It's written "sensitivity" under the phono 1 2 button- you sure you have an au20000?
Big amp with vu meters, off red covers- weighs about 65 lbs?
Oh yes sorry those switches. but all good now sprayed with electrical spray even the circuit board and works fineIt's written "sensitivity" under the phono 1 2 button- you sure you have an au20000?
yes what an amp I don't think I will ever sell mine either and they are so rare I have never seen one for sale here in Australia on ebay.Nice, easy fix! I love mine, it isn't going anywhere!
hi, again When you turn the amp do you hear a click right away followed by a pop then comes out if protection is that normal?Nice, easy fix! I love mine, it isn't going anywhere!
