Sansui AU-217 Restoration
Discussion in 'Exclusively Sansui' started by dedero, Feb 6, 2017.
  1. dedero
    dedero New Member
    16
    Bavaria - Germany
    Hello,
    I'm starting with the restoration of an Sansui AU-217, as far as I could see, the restorations and recap aren't quite often so I would also like to post how everything goes as well.
    I would like to ask you guys regarding the PSU capacitors (6800uf 50V), the thing is the original ones have 4 connectors and the polarity connections have 20mm of lead space but the new caps (I didn't bought any yet but I would like to replace the originals with Nichicon KG series) have 10mm, so I'm a bit stuck here.
    I saw some people from different models modify the board to attach snap-in connections (I don't really like to modify the board) and another guys attach the lug type connections but I'm not sure how they do that, some others replace the original interior with new ones keeping the original external capacitor shape.
    Any help here??.
    Thanks and cheers,
    Bruno.
  2. AUD101
    AUD101 Parsley The Lion!
    604
    "The Big Smoke" - UK
    For the AU-217 and AU-217II - the original 6800uF 50V PSU Electrolytics are 4-pin snap-ins - 35mm diameter - 60mm height - lead spacing of 22.5mm
    Current possible replacement's are
    NOS Panasonic TH-A 8200uF 80V - drop-in replacements currently in stock at Mouser Electronics
    or Nichicon UKW 6800uF 50V also currently in stock at Mouser Electronics - these are leaded which can be bent to the correct required lead spacing
    dedero, Hyperion and smurfer77 like this.
  3. smurfer77
    smurfer77 AK Subscriber Subscriber
    1,510
    San Francisco
    Keep it coming OP. I use to own an AU-217 and thought it was a little champ with sound that embarrasses many of the bigger models. And, we don't see much of the Au-217 on AK as folks are generally more into the higher-powered models or 'TOTL', which I think is a big shame.
  4. dedero
    dedero New Member
    16
    Bavaria - Germany
    Thanks a lot!, I will go for the Panasonic ones because I really like the drop-in replacements.
    I will post further news!
    Cheers,
    Bruno.
  5. jd-audio
    jd-audio Active Member
    483
    Europe
    I also like the AU-217, nice to hear you are putting in time, money and effort to reconditioning one.
    Recently I cleaned some AU-217 toggle switches by using the method described by AK memer Kale (Ithink): Completely reassemble the switch, taking out the small contact parts and cleaning all. Even needed a donor switch as one of the smal contact parts was deformed.
    PITA job but great results, superquiet switching for many years to come.
    Good luck and keep posting
    -John-
    dedero and smurfer77 like this.
  6. dedero
    dedero New Member
    16
    Bavaria - Germany
    Hi John, thanks for sharing your experience! Can I ask you more information about this method? I was searching in the forum and I could not find anything. Thanks!
    Bruno
  7. jd-audio
    483
    Europe
    will
    Hi Bruno,
    Follow this link and you know what I mean.
    http://www.audiokarma.org/forums/index.php?threads/another-sansui-au20000.699933/page-3
    Be aware that you must have patience, a steady hand, a looking glass and a good eyesight (to look for the parts that fall on the floor and seem te be invisable untill you crush them with your foot) to dis-/re-assemble the switches (did I mention patience?).
    Have fun
    -John-
    dedero likes this.
  8. dedero
    dedero New Member
    16
    Bavaria - Germany
    Hey guys,
    I would like to post some progress about this restoration, this is my first one so probably I won't have as much details as expected!
    First, some pictures some minutes after I received the amp:
    The amp itself:
    Some leaking caps, there were several but I took a picture on these only:
    After cleaning, it seems the guy was using it as notebook holder or something like that because there were some sticky sweet alike dirty:
    Recap-Restoration starts here:
    I removed, dissasembled and cleaned every switch (thanks John (jd-audio) for the details!):
    Before switch cleaning:
    After switch cleaning:
    I tried to disassemble all potentiometers but I couldn't make it... the volume and input switch looked a bit complex to be disassembled so I went for cleaning without disassemble (if you have any link regarding how to disassemble them, I will be very thankful!)
    smurfer77 likes this.
  9. dedero
    dedero New Member
    16
    Bavaria - Germany
    Some old vs new caps, I replaced all of them, I used Nichicon MUSE, KZ and FG series and ELNA Silmic II:
    Thanks AUD101 for the details about power supply caps, I decided to go for the Nichicon instead of the drop-in replacement
    Deadly glue!, I decided to remove it mecanically and after 3hours and some small scratches, most of it was gone. I read to remove it with thinner but I wasn't so safe with it, if somebody has any better way, it will be really appreciated!, I was so frustrated with the glue that I forgot to take any picture afterwards:
    Nichicon MUSE over the cleaned circuit board:
    Varistors VD1212 retrofitted with 2 x 1N4148 in series
    Power supply caps in their final resting place:
    Fuse resistors replaced:
    To be done: Replace BIAS timmer pots (I have to pick them up today) and replace old white thermal paste
    I'll keep you posted!
    Hyperion, smurfer77 and skippy124 like this.
  10. smurfer77
    1,510
    San Francisco
    Excellent pics. You are going to have one sweet machine when you are done. Have you been powering it up now and again to check it is still working properly after each stage?
    Cheers
    dedero likes this.
  11. AUD101
    604
    dedero - looking good! :thumbsup:- Here's a method for glue removal from forum member Kico ---> My solution for easy AU-717 Sansui glue removal
    Depending how far you want to go with your AU-217 restoration - you could also change out the speaker relay too
    dedero likes this.
  12. ghamilton
    ghamilton Super Member
    1,535
    ASHEBORO NC
  13. dedero
    dedero New Member
    16
    Bavaria - Germany
    Awesome! thanks for the details!, I will keep in mind for the next restoration.
    Actually I was thinking about changing the speakers relay but I thought the replacement is only when the relay itself doesn't work, but now you are mention it, would be a good idea as well
    Thanks!, Actually yes, I was testing the amp several hours just at low volumes due to the "brake in" process
  14. UptheIrons
    UptheIrons New Member
    18
    He hello nice post about the 217. i am about to do the same with my own recently bought AU-217.
    Do you have an list or something where you put all your capacitors?
    it would be very helpfull!
  15. dedero
    dedero New Member
    16
    Bavaria - Germany
    Hi!, I'm sorry for replying one year later... actually I'm not receiveing e-mail notifications and I'm not sure why...
    Part list, true, that's something I forgot to post, here we go:
    Equalizer Board F-2758
    Equalizer Board C01 1 uF 50 V - REPLACED
    Equalizer Board C02 1 uF 50 V - REPLACED
    Equalizer Board C05 100 uF 6.3 V - REPLACED
    Equalizer Board C06 100 uF 6.3 V - REPLACED
    Equalizer Board C13 47 uF 10 V - REPLACED
    Equalizer Board C14 47 uF 10 V - REPLACED
    Equalizer Board C15 3.3 uF 50 V - REPLACED
    Equalizer Board C16 3.3 uF 50 V - REPLACED
    Equalizer Board C617 220 uF 35 V - REPLACED
    Equalizer Board C618 220 uF 35 V - REPLACED
    Equalizer Board C619 220 uF 35 V - REPLACED
    Power Supply, Protector Circuit y Power Amp Board F-2760
    Power Amp Board C01 1 uF 50 V - REPLACED
    Power Amp Board C02 1 uF 50 V - REPLACED
    Power Amp Board C07 47 uF 50 V - REPLACED
    Power Amp Board C08 47 uF 50 V - REPLACED
    Power Amp Board C09 330 uF 50 V - REPLACED
    Power Amp Board C10 330 uF 50 V - REPLACED
    Power Amp Board C11 47 uF 6.3 V - REPLACED
    Power Amp Board C12 47 uF 6.3 V - REPLACED
    Power Amp Board C15 330 uF 50 V - REPLACED
    Power Amp Board C16 330 uF 50 V - REPLACED
    Power Amp Board C23 100 uF 6.3 V - REPLACED
    Power Amp Board C24 100 uF 6.3 V - REPLACED
    Power Amp Board C25 100 uF 6.3 V - REPLACED
    Power Amp Board C26 100 uF 6.3 V - REPLACED
    Power Amp Board C27 1 uF 50 V - REPLACED
    Power Amp Board C28 1 uF 50 V - REPLACED
    Power Amp Board C29 470 uF 6.3 V - REPLACED
    Power Amp Board C30 470 uF 6.3 V - REPLACED
    Power Amp Board C601 47 uF 6.3 V BIPOLAR - REPLACED ***KEEP BIPOLAR IN MIND***
    Power Amp Board C602 1 uF 50 V BIPOLAR REPLACED ***KEEP BIPOLAR IN MIND***
    Power Amp Board C604 470 uF 6.3 V - REPLACED
    Power Amp Board C605 47 uF 50 V - REPLACED
    Power Amp Board C606 470 uF 50 V - REPLACED
    Power Amp Board C607 470 uF 50 V - REPLACED
    Power Amp Board C608 100 uF 50 V - REPLACED
    Power Amp Board C609 100 uF 50 V - REPLACED
    Power Amp Board C610 100 uF 50 V - REPLACED
    Power Amp Board C611 100 uF 50 V - REPLACED
    Power Amp Board C612 6800 uF 50 V - REPLACED
    Power Amp Board C613 6800 uF 50 V - REPLACED
    Power Amp Board C621 3.3 uF 50 V - REPLACED
    Power Amp Board C622 3.3 uF 50 V - REPLACED
    ====FUSE RESISTORS START=====
    Power Amp Board R39 220 ohm 1/4 W - REPLACED
    Power Amp Board R40 220 ohm 1/4 W - REPLACED
    Power Amp Board R41 220 ohm 1/4 W - REPLACED
    Power Amp Board R42 220 ohm 1/4 W - REPLACED
    Power Amp Board R43 6.8 ohm 1/4 W - REPLACED
    Power Amp Board R44 6.8 ohm 1/4 W - REPLACED
    Power Amp Board R45 6.8 ohm 1/4 W - REPLACED
    Power Amp Board R46 6.8 ohm 1/4 W - REPLACED
    ====FUSE RESISTORS END=====
    Power Amp Board VS01 VD1212 - 2 x 1N4148 in serie - REPLACED
    Power Amp Board VS02 VD1212 - 2 x 1N4148 in serie - REPLACED
    Tone Control Board F-2759
    Balance - Tone Control Board VR01 250 k ohm - CLEANED
    Volume - Tone Control Board VR02 250 k ohm - CLEANED
    2 x Trimpots 470ohm --> extremely difficult to get... one year later and I cannot get it anywhere... the original trimpots were fine to tune the BIAS current
    Speaker relay: Omron MY4-02 DC24 - REPLACED
  16. dedero
    dedero New Member
    16
    Bavaria - Germany
    Hi All,
    I came back again to ask you guys something regarding the speakers relay, the thing is the relay was the last thing to replace, the thing is since the very beginning (I forgot to post earlier) with the new relay, when I turn on/off the amp there is a quite loud "pop", I'm considering cleaning the original one and put it back again...
    Any other suggestions will be appreciated!
    Thanks and cheers,
    Bruno.
  17. Hyperion
    49,192
    Hertfordshire, UK
    When these relays fail, they do so usually because of eroded/worn/badly tarnished contacts, once the contact plating is gone the only cure is relay replacement.
    dedero likes this.
  18. roger2
    roger2 . Subscriber
    3,214
    Are you having trouble finding trimpots because 470ohm is not available? Perhaps you could find and use 500ohm instead?
    I always replace trimpots during a refurb. The older ones are likely open case, as opposed to sealed like their replacements would (should) be, and the materials are inferior to materials in modern trimpots. With a refub as thorough as the one you have done, IMO the old trimpots are by far the weakest link among remaining components.
    I believe that 500ohm trimpots could be used in place of 470ohm without any functional issues. Could someone please either confirm or deny?
    dedero likes this.
  19. Leestereo
    Leestereo Super Member
    2,154
    Ottawa, ON
    Measure the DC offset at the speaker terminals; based on your description, it is likely to be high. If that is the case, the differential input pair IC (2SA798) of the power amplifier stage is failing.
    dedero likes this.
  20. Hyperion
    49,192
    Hertfordshire, UK
    Confirmed - no issues there.
    dedero likes this.
