Sansui AU-217
Discussion in 'Exclusively Sansui' started by Sansui77, May 13, 2018.
  1. Sansui77
    Sansui77 Khosaku Kikuchi's Grandson Subscriber
    588
    Melbourne, Australia
    Hi all,
    Just wondering if someone has an AU-217? I need a photo of the undercarriage if possible please?
  2. restorer-john
    restorer-john Addicted Member
    5,347
    Australia
    Dornier Do 217- under-carriage quite visible:
    Bruins, skippy124 and Sansui77 like this.
  3. restorer-john
    5,347
    Australia
    Here you go:
  4. Sansui77
    588
    Thanks John.
    Wondering where I can get a set of original feet from.
  5. Sansui77
    588
    Just bought this set for the garage but some nuckle head has changed the feet only on the amp not the tuner.
    Another strange thing, the TU-217 seems to have no dial lamps from when Sansui designed this model??
  6. restorer-john
    5,347
    Australia
    Hard plastic feet, no insert soft pads and same as used on the AU-D5/7 and a bunch of other pieces. I can measure my AU-D5 feet for you if you like if that helps.
    edit: I see you have the tuner- same feet?
  7. restorer-john
    5,347
    Australia
    They are hard and can skid on smooth surfaces. Maybe that's why the 'knuckle head' changed them...
    Sansui77 likes this.
  8. p4spooky
    p4spooky New Member
    9
    Portland OR
    Bought these for my AU 317 and AU 217. Did not come with screws, had to get #4 sheet metal screws from Home Depot.
    No affiliation to the seller, but these fit and looks great. Talking about knuckle heads, mine decided to completely remove them to solve the sliding issue I guess ;)
  9. Robisme
    11,571
    Martinez California
    Correct, no dial lights on the TU-217.
    Rob
  10. Sansui77
    588
    I just wanted to make sure the feet are the same on both the AU/TU. I might just leave it as is. I understand the change to stop the AU from sliding etc.
    Thanks to all for your responses, really appreciate it.
