MCM_Fan
AK Subscriber
I have a Sansui AU-717 that I bought about 4 years ago. It was my daily driver for about a year and I liked it very much. That is, until one morning about a year after I bought it, it started making a buzzing noise out of both channels. I shut it down immediately and pulled it from my system. This buzzing is present at all levels, and only increases very slight as the volume is turned up.
It is present with all sources and in both the left and right channels with both the Speaker A and Speaker B outputs. The amp still produces music and other than the buzzing, sounds and functions fine.
I finally got around to popping the cover this morning and can see some of the dreaded glue damage, but at first glance it doesn't look as bad as some of the photos I've seen. I would like to attempt a compete recap and cleaning of the glue residue and replacement of any damaged components.
There are several threads on that process, but unfortunately many have been rendered nearly useless by the Photobucket 3rd party hosting fiasco.
In the meantime, before I get around to the recapping and complete cleaning are there any quick suggestions as to what might be the source of this buzzing? Since it is in both channels and nearly constant volume and the amp is otherwise functional, is the power supply board the likely culprit and where I should start my investigation?
