Hi All!,
I'm starting the planing the restoration of a just bought AU-717, I could read the very useful information around this forum regarding this amazing amplifier, as this will be my 3rd amp restoration (after a successful AU-217 and AU-317 ones), I feel enthusiastic enough to go forward with this amp.
I bought it for 350eur aesthetically mint condition but unfortunately with a protection problem which I would like to detail:
- Turning the amp on, the protection LED blinks permanently and the relay is never engaged
- While the LED is blinking I tested with my headphones and the good news is that both channels are working perfectly
- After some minutes (around 10) I started to feel some heat coming from the protection board F-2663 so I could realized that the transistors TR01-TR02-TR03-TR04 were quite warm, not really untouchable hot but getting warmer with the time
- BIAS current was around 25mV for both channels (20mV is the correct one as per service manual)
- DC Offset didn't measure anything as the relay is never engaged (just an assumption)
NOTE: It seems this amp was working quite hot for some time as several caps alongside the protection board F-2663 have their cover a bit shrank (I hope this is the correct expression) and the board itself it's a little bit bended, in addition to that, the deadly caps glue is really dry/roasted alongside the whole amplifier
As I could see, the protection board is not really easy to take out in order to test the voltages shown in the service manual right away, I'm thinking 2 options:
- Restore every single board: replace caps, diodes, fuse resistors, trimpots, relay, pots cleaning, check cold/broken solder joints, etc etc etc and then search and resolve the problem
- Repair the actual issue, make sure everything is working as it should and the restore it afterwards (I'm considering this option just in case there's a problem with one or several transistors)
What do you think could be the issue with the protection and what do you think which direction should I take?
Any advice will be really appreciated!
Cheers,
Bruno.
Cheers,
Bruno.
