Jamaica1985
New Member
Hey guys!
Not long ago I posted pictures of my new (obviously used ) Sansui AU-719 which probably sat for a long time without any use in some place however with time it did develop some issues that were not discovered until a few weeks I had it running . After some time of light use it started to develop a light hiss on the background from both speakers, the balance pot started to produce some cracking noises out of the speakers when turning both directions and not being bothered by it too much I just kept on using it… Well, that’s where I should´ve stopped because not long after both of my tweeters made a horrible burning noise and they were gone… literally before I could turn of my amplifier I saw the magic white smoke being released from the area where the power amps are located, giving me little tears in my eyes, and no this was not because of the smoke…
I opened the device up and what first caught my eye is that 2 of 5 fuses were blown, but it looked like, since the rest were glass fuses, the ones that broke were those slow blowing versions with white powder in it, making me think that this amplifier had problems before they sold it to me and they simply put in some slow blowing fuses to keep it working...
Now, after reviewing the device further I noticed the famous Sansui glue literally almost rotted through a couple of resistors and diodes and even a jumper cable making me wanting instead of troubleshooting all that could be wrong, simple replace everything, and by everything I mean literally everything that is possible to be replaced.
Now then again I do not know if this is a wise solution because I´m sure some of the components are just fine, but since I will likely be removing everything from the boards anyway to give the boards a proper cleaning and tin job I might as well put in new components given that this will likely be a multiple month job anyway.
Some of the things that I will have to do first is:
- Completely disassemble the device. Done
- Buy a better Multi-meter since my crappy 5 dollar one probably is not gonna cut it
- Buy a soldering device, whether it is a station or one of those simple suckers, I don´t mind
- Considering an oscilloscope however I´m not in the mood to spend hundreds of dollars at this point
- Buy all if not most of the replacement components on Mouser
Some of my initial questions I have so far are:
- I really don´t know the wattage of these old resistors, would that be a 1/4 Watt for the yellow ones, 1/2 Watt for the green and blue ones and 1 Watt for the large blue ones?
- Hoping that a good multi-meter can check the functionality of the power amp components, what other can I do to check if they still function? Can you simply do Ohm readings between BCE? If they are shorted, is there any suitable replacement for these?
Lastly I want to thank user jeromach for providing me a component list with a lot of information on it. This has helped me a lot to identify most of the components.
Again, this project will likely turn into months, but any progress will be posted in this thread for sure. The problem I have, as with most people I assume... is money and time, where money is always the biggest issue
And since , I am attaching the disappointing pictures below...
