Sansui AU-919 Back coupler switch missing?
Discussion in 'Exclusively Sansui' started by Brad Muller, Dec 26, 2015.
  1. Brad Muller
    Brad Muller Super Member
    4,707
    Vancouver, Wa
    Why would someone remove the rear coupler switch on Sansui AU-919?
  2. Hyperion
    41,381
    Hertfordshire, UK
    Because it is implicated in channel dropout issues, easily resolved with a proper cleaning of the switch. And presumably removed because they have no idea what they are doing.
    In short, you do not know how to clean a switch properly if your solution is to remove the switch - and leave it removed.
  3. Brad Muller
    4,707
    Vancouver, Wa
    So now I have to replace the switch.
  4. Hyperion
    41,381
    Hertfordshire, UK
    You should try to get another one - not sure where from though, 'Sansui Parts Shop' - does not seem to have them.
  5. Brad Muller
    4,707
    Vancouver, Wa
    I'll find one. Thanks!
  6. LBPete
    11,007
    Long Beach, CA
    It should be a fairly standard pc mount slide switch. You can probably find a new switch that will drop right in.
    - Pete
  7. LBPete
    11,007
    Long Beach, CA
    I think these switches are double pole three position, on-on-on but I'm not sure so please check. Digikey has this one. [​IMG]
    - Pete
    Hyperion likes this.
  8. Hyperion
    41,381
    Hertfordshire, UK
    I actually thought there was something special about this one, I can't think why now :dunno: anyway Pete's cinemascope picture suggestion above looks good to me. :D
  9. LBPete
    11,007
    Long Beach, CA
    Sorry about the size of the picture. I inserted a link to Digikey's image and I don't see how to adjust the size. In any case, you can see the detail, right?
    It is an unusual switch because it needs three positions each of which turns something on. Unfortunately this one is not metric. You can probably find a metric one with a little more digging. Here's the data sheet for this one.
    - Pete
  10. LBPete
    11,007
    Long Beach, CA
    I've been reading more about these switches. They come in shorting and non shorting - - - make before break or break before make. That would be important to know so you don't cross connect stuff that shouldn't be cross connected. The switch mounts on board F-2838. The diagram for that board in the service manual shows the pin layout for the switch. There are two pins set off from the others. That means this one with gold contacts may fit. It's metric but doesn't have the mounting holes to attach it to the back panel. It's also a make before break switch.
    - Pete
  11. Brad Muller
    4,707
    Vancouver, Wa
    Thanks for all your help Pete!
  12. ghamilton
    ghamilton Super Member
    1,323
    ASHEBORO NC
    I need to order one of these for my 919. Did anybody ever figure out what switch to order?
  13. LBPete
    11,007
    Long Beach, CA
    I haven't had reason to order one. The second one has the closest pin layout.
    - Pete
  14. ghamilton
    1,323
    ASHEBORO NC
    If I knew how to bypass it I would. I removed the switch because it's had it. I'm just waiting for advice which way to go.
  15. ghamilton
    1,323
    ASHEBORO NC
    Pete,. I looked up the contact positions of the switch you thought would work and I figured out which pins to connect with the switch in the "Connected" position and made some little jumpers. After removing the switch off of the board I used the jumpers in it's place. It sounds even better now and no more stupid rear-switch problems either.
  16. RobinTW
    RobinTW New Member
    48
    Taipei, Taiwan
