Sansui AU-9500 filter caps and rectifers
Discussion in 'Exclusively Sansui' started by Mico, Feb 28, 2018.
  1. Mico
    Mico Active Member
    374
    Montreal
    I am completing parts order for AU-9500 restoration, one last thing I am not sure about are filter caps and rectifiers. Original caps are puny 4700mF and should be brought up to at least 6800mF but what worries me are the rectifiers. They are already well known to be unreliable and upping the capacitance would put even more stress on them. Which rectifiers would be a good solution, either as plane replacement with original 4700mF values or even better for 6800mf - 10.000mF ? And what about the power switch, would stock one be O.K. in 9500 "turbo" version?
    BLAH BLAH likes this.
  2. kevzep
    I put 10,000µF caps in my one on the standard rectifiers, as far as I know after selling it to a colleague, its still running.
    Although it wouldn't hurt to throw some up-rated rectifiers in there....just for preventative maintenance.
    slimecity and pete_mac like this.
  3. Mico
    Mico Active Member
    374
    Montreal
    Thanks Kevin, I will go for 10.000 than. Is there any chance you know what values are bias and DC offset adjusting trimmers?
    Can not figure that out from SM and old ones are so badly oxidized I would not dare to touch it, let alone adjust anything.
  4. Hyperion
    49,228
    Hertfordshire, UK
    Is what I could find in the SM - but maybe you should measure yours with a multimeter just to be sure?
    slimecity likes this.
  5. slimecity
    slimecity Super Member
    3,156
    New Zealand
    The schematic may also describe the trimmer values in the circuit diagram - have a look at that too.
  6. Leestereo
    Leestereo Super Member
    2,155
    Ottawa, ON
    +1
    Installed 10,000µF/63V Nichicon KG capacitors >2 years ago and no issues to date.
  7. Leestereo
    2,155
    Ottawa, ON
    Trimmer VR801 is 5kohm; VR803 is 200ohm.
  8. Mico
    Mico Active Member
    374
    Montreal
    Thanks Lee, I forgot to look at your excellent post regarding 9500 restoration. It was beautifully illustrated - but none of the images are available any more, did you think
    about uploading them directly on AK again? Hyperion`s image of SM with VR-802 marked as Bias trim pot is confusing, same as I see in my SM - and no VR-803 in the parts list? But in that same SM, VR-803 is noted in Bias adjusting procedure...obviously another Service Manual mistake.
  9. Leestereo
    2,155
    Ottawa, ON
    The thread images are still on Photobucket; they have changed its 3rd party hosting policy and this has affected most of my AK threads. The embedded Photobucket pictures can be viewed with a Chrome Extension (https://chrome.google.com/webstore/...nk-fix/kegnjbncdcliihbemealioapbifiaedg?hl=en) or a Firefox Add-on (https://addons.mozilla.org/en-US/firefox/addon/photobucket-embedded-fix/).
    I have noticed that at different times one or the other workaround will stop working; currently, at the time of writing, the Chrome workaround allow the pictures to be viewed within the thread.
    Regarding VR-803 is the notation for the bias adjustment trimmer in the schematic.
  10. kevzep
    Nice job getting the Gold Tunes in there....not always an easy fit..
  11. Mico
    Mico Active Member
    374
    Montreal
    Big 10.000mF KG caps are in but did not upgrade rectifiers yet....very awkward position of bridge rectifiers and limited space to deal with.
    So far so good , will try to ft in at least 10A bridges instead of originals.
    Hipocrates likes this.
  12. Mico
    Mico Active Member
    374
    Montreal
    Went to adjust Bias on Au-9500 and found this...someone at Sansui liked Russian roulette - distance was less than 1mm!
  13. Hipocrates
    Hipocrates Anti-Muppet Subscriber
    1,855
    Costa Rica
    They are connected to the same spot, don't worry.
  14. Mico
    Mico Active Member
    374
    Montreal
    Got it, still flimsy craftsmanship.
  15. kevzep
    Yep same junction, no problem there at all, sometimes they use plastic sleeve over the legs sometimes not....
  16. Leestereo
    2,155
    Ottawa, ON
    Here is a picture of a potentially more damaging situation (yellow arrows point to clipped off pieces from the output transistor leads):
  17. Mico
    Mico Active Member
    374
    Montreal
    Yikes, are they hanging from the thermal compound? Which unit was that ?
  18. Leestereo
    2,155
    Ottawa, ON
    Yes, just waiting to fall and cause a short...Adcom GFA-545.
