LordJim
I just acquired a au-9900 in very nice shape. I was a little suspicious, cause I got it for a fairly good price (300$) and the owner had a lot of good audio gear, and it surprised me that he would let this nice piece go.
Before hooking it up i opened it and everything looked very nice, and from the looks it seems that nobody has worked on this unit before. When I hooked it up, i was a bit disappointed, cause the music felt a bit lifeless and there seemed to be very little bottom end too. When i measured the bias on the speaker outlets i got -120mv and -60mv, so i opened here to adjust the bias.
I'm not sure if I'm doing it right. In order to get the measurement, i have to unplug the red cable and hook up my multimeter between the red cable plug and 06 (or 01 for right side), as seen in this picture, right ?
the measurement reads 46.5v on both sides, but I'm unable to adjust anything by moving vr03 and vr04. I'm also not able to adjust the bias at the speaker terminals with vr01 and vr02.
I have read dr*audio's post and unless i'm doing something wrong i suspect it's the transistors on the amplifier board 2583 (in my case). If that is the case, i could uninstall the amplifier board and take it to my tech, who probably has some replacement transistors and can install them. I found a pic on the web, and it would be very helpful if somebody who has done the job to point out which transistors to change.
cheers, ingo
cheers, ingo
