Sansui AU-X1 speaker relays.....
Discussion in 'Exclusively Sansui' started by slimecity, Sep 14, 2018.
  1. slimecity
    slimecity Super Member
    3,155
    New Zealand
    Hi there Sansui Nerds
    Has anyone replaced these in their X1? Is a current drop-in modern type available without any modification?
    I have one channel with very slight distortion at low volume which goes away once the volume is increased a bit, suggesting relay issues IMO.
    cheers!
  2. slimecity
    3,155
    New Zealand
  3. OverLoad
    OverLoad High On Solder Fumes
    1,376
    Ontario, Canada
    Hyperion likes this.
  4. Hyperion
    49,215
    Hertfordshire, UK
  5. slimecity
    3,155
    New Zealand
    Phew, cheers - yea I thought that other part was a bit spency.......
  6. kevzep
    Yep, gotta have the "0" in the part number which means through hole...
    slimecity likes this.
  7. Hyperion
    49,215
    Hertfordshire, UK
    Your knowledge of Omron part numbers is being exercised lately. :thumbsup:
  8. Vintagear
    Vintagear AK Subscriber Subscriber
    1,609
    Wow, that was a fast response time! I knew I had a picture of mine saved somewhere, finally found it and it looks like you got the right answer (you can make out the LY2 - 0 24VDC in the pic). Good luck, I hope the replacements solve your issue.
  9. kevzep
    Yeah I have had a run of jobs lately that need relays....so getting familiar with the part numbers...
  10. slimecity
    3,155
    New Zealand
    Cheers - it will solve one issue - dont worry there are several other issues in my X1 to also sort out! lols
    Vintagear likes this.
  11. slimecity
    3,155
    New Zealand
    Just curious about the large resistors by the speaker relays - are they some sort of dummy load to improve output stability if the speakers are switched off?
    What is their purpose?
  12. Hyperion
    49,215
    Hertfordshire, UK
    They are part of a 'Boucherot Cell' (sometimes called a 'Zobel Network') comprising one resistor and one capacitor (per channel) to damp high frequency oscillations at any time, but especially when the speakers are disconnected. :)
    This arrangement is very common in audio amplifiers, and if an amplifier is unstable and oscillating (at a high frequency) those resistors can get extremely hot.
  13. slimecity
    3,155
    New Zealand
    Sweet - thanks hyperion. I've seen zobels in amp output stages before but the resistors have so far not been this huge!
