Hi there,
I've been reading your posts for a while and fellow vintage Sansui fan recommended to post a topic here.
I got nice AU-X11, which went for quick check-up/service. Quick inspection seemed ok. There was nothing alarming and ''All circuit elements appear to be working correctly'' but then there is no sound from speakers or from headphone. ''The unit is either in mute, which it doesn’t appear to be, or there is a broken signal path.'' We decided to call it quits for the repairs as it might be very expensive exercise for now.
We then talked about maybe keeping it powered on for a while and maybe I get something out. And I did after hour or two. Headphone output worked and kept it going for few hours. I turned it off/on at one stage to see what happens. No change...but when I kept it off slightly longer and moved it to a table, then I lost signal again. And haven't got it back yet.
I'm planning most likely to do full restoration someday but this is not cheap. I cannot put money into that at this moment. But I would like to enjoy it little before restoration.
I would appreciate if someone would like to advice what might be the possible cause here.
