sansuibutch
Super Member
I want to get rid of the crappy connectecors on my ba2000 and install banana plug binding posts. Can anyone post a few pics and tell me where they sourced thers? Thank you .
Here's one for an AU-717 which uses the same spring speaker connectors as the BA-2000: AU-717 Binding Posts
Edit: Also see Speaker Binding Post Mod for 317/417/517/717
https://www.google.com/search?q=5+w...=1280#imgrc=6HSW5DUiccQ7dM:&spf=1521488475886There are many different ones in those threads. Post a picture of the ones you like and we might be able to tell you where to get them from.
Like this
https://www.parts-express.com/gold-binding-post-pair-insulated--091-1140
Or these from Superior Electric BP21B & BP21R http://www.newark.com/c/test-measur...t-clips/binding-posts?brand=superior-electric
You'll have to measure your existing ones in your BA - or converse with someone who has done this upgrade on a BA-2000 - I have no idea if the ones in the links above will do the trick.
The ones I get - TP5L - aren't listed in their standard range. They are 30A terminals like the TP6 series, but have the thinner plastic shroud like the TP1 series. I get them direct from the local Cliff branch here in Aus, there is a local US Cliff branch that may deal direct
Edit - Cliff US details
http://www.cliffinc.com/contact/index.htm
Cheers
John
Hi,
Just checked what I have in stock, and it is the TP5S - the short version - that I use (not the TP5L long version)
the PDF is attached
