mplsbob
I posted on this a few weeks ago, and it was seemingly deleted - possibly because my testing wasn't complete? - but I'd like to start a discussion again.
I recently purchased replacement caps for both driver boards, and the two large power supply caps and two large output caps for a Sansui 5000X. The big caps arrived first, so I decided to tackle them. After replacing all four, I reset the current and output adjustments and fired it up. To say the result was surprising is an understatement. The unit sounded like it had been neutered. The impressive low end was gone, leaving me only the option of utilizing the loudness button to make it listenable. I let it ride for a while to see if I just needed to adjust to the change in sound, but my perception just wasn't going to change - it wasn't good. I put the old caps back in, and it's back to its hearty old self.
My question is: Has anyone else had this experience replacing caps? One previous poster suggested that when caps drift out of spec over the years they can become (in my case) 2200uf caps that function like 3300+uf caps, thus allowing for a more robust - though possibly sloppy - bottom end. Another stated "silicon"(?) caps are a bad replacement for Sansuis.
Any input out there on any of this? My 2200uf replacements were Digikey's recommended part #p7364-nd.
Sorry for the long post.
