Sansui FR-D4 turntable doesnt autolift
Discussion in 'Turntables' started by bloodrock, Jun 12, 2007.
  1. bloodrock
    bloodrock Active Member
    240
    Picked up a very clean Sansui FR-D4 semi-automatic table. The arm doesnt lift at the end of play, so what should I look for? Is it a computer glitch? The arm lift doesnt raise at any point whether begining or end. Maybe a related issue is that the table's voltage was set at 220 when I picked it up, but when I got it home, realized this and set it at 120. All lights and other functions work.
  2. hakaplan
    hakaplan Needs professional help
    10,704
    Philadelphia, PA
    Often these have a lamp and photo-sensor that triggers the auto-return. If that's the case, the lamp could be burned out. You might open it up and see if there's anything obvious, but usually the service manual helps. There's one on ebay--not cheap, but if you like the table, it may be worth it.
  3. bloodrock
    240
    Sansui FR-D4
    Hi Howard,
    Actually it was given to me by the seller of a Sansui TU717 I picked up from him. It wasnt working according to him, so he threw it in with the tuner. The table has an AT14sa cartridge on it, so swapped it for the Shure Premier on my PS-X75. Unfortunately the AT let's me hear more of the unwanted noise on the vinyl. Seems to have much more detail then the Shure. I will check the lamp and see if this is the problem. Thanks Howard.
  4. BRANE
    BRANE New Member
    4
    I have the same turntable and the same problem!
    How did you solved the problem?
  5. Stanton681EEES
    Stanton681EEES Addicted Member
    7,332
    NE Ohio
  6. emartine
    emartine New Member
    38
    Buenos Aires
    Same turntable, same problem.
    I have repair manual downloaded here:
    http://www.eserviceinfo.com/downloadsm/51251/Sansui_FRD4.html
    Is the problem caused by a lamp and/or photo-sensor, or is it the MB8844 IC ?????
    Anyone???
    Thanks!
  7. krisbee
    krisbee Active Member
    163
    I disabled the autolift on my fr d3... I felt that the audio got better with less things affecting the arm, so there is another viewpoint.
