Quasi semi
New Member
Thanks to previous threads on the G-7500 I was able to fix this great receiver. Turns out one of the trim pots killed some resistors and transistors. Recapped, new transistors on the power board and it's humming right along. Last issue is the dial and meter lights. Replaced lamps with 8v 250ma bulbs but no lights. Measured voltage turned out to be 4 volts instead of 8 volts, so I am perplexed to say the least. Any ideas would be appreciated, or which circuit I can tap into to install LED's.
