sansuibutch
Super Member
I have recently acquired these receivers. They both semm to work very well but the glue on the power supply has to go. I'm not to familiar with these amps that much but it seems the pre drivers and power supply share the same board? Would it be safe to say the boards in both these receivers are exactly the same, just a couple different value capacitors? Here is a pic of the g7700 board and appears to have a few caps previously replaced (circled ones). I noticed right away since somebody upped the voltage on a couple of them, and the low leakage caps that are on the 5700 board are black on here. It looks like just the biggest caps are different between the two receiver boards. Would this be the case? Seems all the smaller caps should be the same between them. I also read about what a nightmare these board can be in these particular receivers. I'm figuring just replacing the caps and cleaning glue will be as easy as it looks with no I'll effects? Any thought on this? Thank you
