Sansui preamps CA2000 vs CA3000 any thoughts?
Discussion in 'Exclusively Sansui' started by sfpepper, May 26, 2005.
  1. sfpepper
    sfpepper New Member
    4
    Putting dollar differences aside...does anyone have any thoughts on the sonics of the CA2000 vs CA3000? TIA steve
  2. Jethro_hifi
    Jethro_hifi New Member
    12
    Zagreb, Croatia
    Hi, I would like to acquire one of those two preamps, and found some interesting info somewhere on this forum that “people like the ca2000 even better then the ca3000”.
    Why is that? Can somebody explain real sonic differences?
    Thanks!
    BR, J
  3. Jethro_hifi
    12
    Zagreb, Croatia
    Knock, knock, knock...
    Is any body home? :scratch2:
  4. nosirrah
    nosirrah Moderator Staff Member Moderator Subscriber
    7,454
    30 min north of seattle
    Home?
    Nope....
    Never listened to the CA 2k, love the 3k...
    Casey
  5. johnny_fever
    johnny_fever Walk tall & carry a big G Subscriber
    1,279
    IL
    I can say I'm real happy with my CA-3000. Not sure about the Ca-2000.
    I have heard neg comments about the problems with the 150 or 180 feed throughs. Maybe someone else can chime in. Later Rick
  6. kenwood61
    kenwood61 Vintage HiFi Nut Subscriber
    4,850
    Bend, OR
    I really enjoy my CA-2000, and just picked up the 3000. Specs show the 3000 should be noticeably better in terms of headroom, the amount of control you have over the signal, and improved specs.
    Visually speaking, I like each in different ways. I like the knob layout of the 2k better, but the meters on the 3k are cool, and useful for calibration.
    What I didn't realize before I got the 3k, was that there is no Output Selector knob, like there is on the 2k . . . so in the end, I may prefer the 2k simply because I prefer to control two amp/speaker setups, independently of each other through a switch . . . although you can obviously control which amp/set of speakers play simply by turning on the amp you want to run.
    I am curious about comments on the difference between volume control. I notice the 2k has a lighter touch. The volume on the 3k requires a little more force to turn.
  7. torca
    torca Member
    72
    I have both and prefer the CA3000,looks and performance wise. Both pre's have excellent sound characteristics, but I find the phono pre on the 3000 better sounding.May be that both share the same circuitry ,which wouldn't be suprising but the 3000 has far better mid/high frequency definition.I know some people prefer the volume,step attenuator volume control of the CA 2000,but not me.The 3000 has such a smooth accurate feel through the whole range I never get stuck on a "step" that the 2000 volume control offers(though the 2000 is better than most with this step attenuator).Yes the meters are beautiful to look at,and also a very useful as determining the phono cartridge load,utilizing the meter output so as to not overload phono capacitance. The CA3000 costs substantially more than the 2000 usually though,and can't say that the 2000 feels like a huge sonic sacrifice when compared,so either represents good value and great sound.
    sansuibutch likes this.
  8. shelby1420
    shelby1420 Enjoying the music.....
    4,296
    St. Catharines, ON-Canada
    Have owned both and have had both re capped and updated, almost identical insides with the volume pott being slighty better quality on the CA 2000, both lovely pieces!!
  9. kenwood61
    4,850
    Bend, OR
    Do you think this was due to the BA series having level controls?
  10. shelby1420
    4,296
    Hmmmm, not sure to be honest with you, sounds reasonable though......
  11. camilo yyz
    camilo yyz New Member
    11
    yyz
  12. camilo yyz
    11
    yyz
    Hello, I just picked up a CA2000. Not sure about the volume pot. If it is original or not. It is not stepped but smooth in turning it. Is that the original?
  13. craggd
    craggd AK Subscriber Subscriber
    415
    NorCal
    ??? There isn't a knob but there are "Inputs 1 & 2" buttons. Easily supports two amps.
    I own both and I like them both. I don't think you would go wrong with either. The pass through's on the 3k will need addressing, just a matter of time and not a simple task (I outsourced). Significantly less cost on the 2k as mentioned. The 3k is visually a more impressive amp.
  14. sansuibutch
    sansuibutch Well-Known Member
    579
    I also own both and compared them in the same setup. The 3000 sounds a bit better overall. My 2000 volume pot is smooth with no steps.
  15. JOMARK911
    JOMARK911 Super Member
    2,529
    Athens Greece
    Well actually there are two outputs on CA3K not selectable though.
  16. craggd
    415
    NorCal
    John, not sure what I am missing but I have two amps connected and toggle back and forth with the input switch 1 - 2 below the source switch.
  17. fernarias
    fernarias Super Member
    1,056
    Merced, CA
    They are talking about outputs to amps being selectable not sources being selectable.
    To me, the CA-2000 is like the AU-9900 without the amp and the CA-3000 is like the AU-2000 without the amp. Insides look the same. Too bad they didn't make a BA-2000A since I prefer the 9900A.
  18. JOMARK911
    2,529
    Athens Greece
    Dave the switch 1-2 you refer to is phono 1 and phono 2 . These are selectable yes. But you can't connect a pre amp on phono input. I hope you haven't. If you have you probably have messed up the phono input.
  19. craggd
    415
    NorCal
    No I haven't connected an amp through the phone inputs. I was under the misguided impression that those buttons switched the amp input from 1 to 2. I now realize that it is just which amp is on. It is somewhat odd there would not be a amp input selector on the CA-3k like there is on the CA-2k.
  20. JOMARK911
    2,529
    Athens Greece
    Not which amp is on , but which phono input, is on the phono amp. There is only one phono amp.
