You didn't mention which lights?
Unlike most Sui's, this one uses a globe type lamp on the side of the dial that transmits light thru the glass.
Those are difficult to find. I ended up using
12v high intensity warm white LED automotive style lamps on my 9001. You need to swap the base, but that's as easy as straightening out the leads, sliding the automotive base off the bulb, and replacing it with the Sui base.
The results are a real close match to the original bulbs, but with better spread across the dial, using the stock 7vac power ...
Ditto for the signal and tuning meters.
The dial color is provided by the plastic shields around the bulbs. Those slide right out, so I suppose you could get creative with the color.
PS - if your power meters are ok, I'd leave those alone. They use a standard wheat grain type bulb, but those are glued into the meters and are a real PITA to replace without damagine the meters. Don't forget, old plastic can be brittle, so don't say I didn't warn ya ...
Worth mentioning - the stock light circuit is 7v
Ac, and LEDs expect to see v
Dc, so expect to see some flickering if you just hook them up straight. I went the easy route to avoid this and added a handy dandy rectifier to the circuit.
I didn't replace the power meter lamps, so those are hooked up before the rectifier and still VAC. All the LEDs are on the other side of the rectifier for VDC. No flicker, and me happy with the results. Google "LED rectifier" on da bay and it pops right up.
