Sansui QS-500 Help!
Discussion in 'Exclusively Sansui' started by danconway327, Mar 20, 2017.
  1. danconway327
    danconway327 Active Member
    148
    Florida USofA
    So I picked up a nicotine soaked and drenched Sansui QS-500 and am not sure what I got.
    Could I hook this up to my Pioneer SX-990?
  2. sKiZo
    sKiZo Hates received: 8641 Subscriber
    It has built in rear amps, so hook it up to any stereo receiver and get the extra channels. Tricky part is balancing the output between your receiver and the adapter ... I went through the basics here ...
    http://audiokarma.org/forums/index.php?threads/sansui-qs-500.431625/#post-5558912
    Nice little box, even if it only has the basic decoders. Sansui's synth modes are quite tasty. Rather than go for OMG total surround sound, I suggest adding a set of good bookshelf speakers for the rears and just using them for ambiance ... That's how I work quad here ...
    If you like what you hear, pop the cover and set it out in the hot sun for a couple days ... that's the best way I've found to get the smoke of ages outta the things.
    PS ... they clean up real purty they do ...
    DaveWho1 likes this.
  3. danconway327
    148
    Florida USofA
    Nice Skizo. I have a little work to do. But for $15.00 I couldn't pass it up. 20170320_075900.jpg
  4. danconway327
    148
    Florida USofA
  5. sKiZo
    Pretty straightforward ... just connect the QS500 to the receiver's tape loop using the front amp outputs. Front amp speakers are hooked up as normal, rear speakers go to the QS500 which has it's own built in amps. The two channel tape loop on the back of the QS500 replaces the one you lose on the Pioneer, and you can also hook a direct quad tape deck to the Sansui if you like.
    DO read the section in my previous link on balancing the output though ... that can be a bit of a head scratcher first time around.
    Forgot I had this ... here's the service manual ... enjoy!
    http://www.brainfartz.com/images/Stereo Stuff/quad/sansui qs500 manual bw.pdf
  6. LBPete
    11,266
    Long Beach, CA
    Nicotine soaked audio gear is a scary reminder of the danger of second hand smoke.
    Can you post the serial number for the database? Click on the link below.
    - Pete
  7. danconway327
    148
    Florida USofA
    Sure, I should get to it this weekend.
  8. danconway327
    148
    Florida USofA
    DOES ANYONE HAVE AN OPERATION MANUAL ( NOT A SCHEMATIC) FOR THIS?
    Thanks
