stereofun
Super Member
Been looking here at the site and Hifi-engine. No Sansui Six manual to be found ?
I just need to do the dc-offset and bias setting. The amp section looks very similar to the Seven - assuming the procedure is the same, all I would need is the Bias mA, then follow the Seven procedure ?
Also came across something curios with this Six. Fm reception is extremely limited using just the onboard antenna - however once a 10 inch wire is connected to the 300 ohm post, the signal is in full force with great stereo sound but you really have to "hold" the wire right. The other 4 single digits I have had all managed reasonable reception with onboard antenna, and where far more forgiving when connecting a wire. hmm ??
Thanks for help as always!!!
