Sansui TOTL Speakers SP-5000 and SP-5500 Side By Side?
Discussion in 'Exclusively Sansui' started by 4-2-7, Apr 4, 2015.
  1. 4-2-7
    25,787
    San Francisco Peninsula
    Well since there is not that much, well nothing really when searching these speaker, how about a SP-5000 and SP-5500 Side By Side?
    I'm right in the middel of taking lots of photos so stay tuned in and see how they compair.
    moefuzz, NeedForSpeed and Sansui_Boy like this.
  2. VintagePlus
    VintagePlus Mcintosh and B&W
    2,422
    Nanaimo BC
  3. 4-2-7
    25,787
    Sansui SP-5000
    (1) 15" woofer
    (2) 6.5" low midranges
    (2) 4" high midranges
    (2) 2.5" horn-type tweeters
    Sensitivity = 102db/100watt
    8 ohm system (6 to 15 range with no loss of efficiency)
    Frequency range = 30 - 20,000 (at Anechoic Chamber)
    Frequency range = 25 - 20,000 (at Normal Listening room)
    Dimensions = 19.25" Wide x 32.6" High x 16.6" Deep
    Weight = 90.3 pounds
    Finish = Oiled walnut (also with the wood fretwork grilles)
    Don't believe everything on the internet, I always thought these specs were correct. They say 100 watts but that's not what the xovers says.
  4. 4-2-7
    25,787
  5. 4-2-7
    25,787
    I'll mention here that both cabinets are made of 1" partical board but the sp-5500 is early MDF. The 5500 has butt and dado joints were as the 5000 is 45 degree miter joints. Back panels are all 1" stock as well.
  6. BLAH BLAH
    BLAH BLAH AK Subscriber Subscriber
    2,318
    Melbourne. ..Australia. ..
    When my 5000 is cranking its like the sound of rolling thunder approaching...awesome sound...punchy bass...
    Man I do like those 5500's horns...
    slow_jazz likes this.
  7. 4-2-7
    25,787
    SP-5500
    Under this thick padding Sansui put a 15" x 1" disc of parical board to take up cubic space or to thicken the back pannel to two inches right behind the woofer.
  8. 4-2-7
    25,787
    The horns are cast aluminum with tig welded deviders.
    BLAH BLAH likes this.
  9. BLAH BLAH
    2,318
    Wow...those cabinets just ooze solidness....beautiful...
    Great pictures...:thmbsp:
  10. 4-2-7
    25,787
    SP-5000
    A few things to note is the sp-5000 differs in an open box, thin dampening matirial, all wiring is soldered.
  11. BLAH BLAH
    2,318
    Ahhhh...all those sansui stickers!!!...:banana:
    bluesky likes this.
  12. 4-2-7
    25,787
    One thing about the SP-5000 all driver are clearly marked as to the speaker and location they go.
  13. captouch
    captouch AK Subscriber Subscriber
    4,266
    Bay Area, CA
    Great pics.
    Looks like all caps are original? You may want to recap them after you listen to them awhile as is and see if sound improved with new caps.
    onwardjames likes this.
  14. patfont
    patfont AK Subscriber Subscriber
    2,780
    South Jersey
    Wow! Thanks for the documentation. It may take awhile but make sure to gently tighten all the driver screws.:scratch2:
  15. 4-2-7
    25,787
    Hi Eric...The only speakers I have that had a recap I bought from you..:D
    Well you know I have had the sp-5000 for a while and tried chasing a "Better" sound around. I started to give up power output for detail, also the mc275 are so clean sounding, it was like an SS system.
    I started thinking of bringing the sp-5000 back into the mix and maybe give them an overhaul. I have three of them and will do one recap to see if SQ is gained.
    NeedForSpeed likes this.
  16. 4-2-7
    25,787
    I'm still looking for specs on the SP-5500 I think I have some brosurs in my files somewhere.
    I got the 5500 local to me from an air force captain that brought them back home with him. These things were so well cared for, hardly any dust inside and I don't think the covers were ever taken off.
  17. 4-2-7
    25,787
    Here is some info fom another one of our own AKers.
    http://www.audiokarma.org/forums/showthread.php?t=525320
    SP-5500
    This is a four-way system with six individual drivers, including a 15" woofer, a large midrange horn, 2 cone-type midrange speakers, and two horn tweeters. The 15" woofer has a massive 7" magnet, a copper voice coil, and a high-quality brass bobbin. It also employs a special voice coil assembly that operates as a high-cut filter, thereby eliminating the need for low frequency crossover. In addition to the large horn midrange driver, it has dual 5" midrange speakers that employ special aluminum concave radiators for smooth response over the entire range. The dual aluminum horn tweeters are coupled to an acoustical lens. There are dual 3-position switches on the back for high and low range sound tailoring to room acoustics and personal tastes.
  18. kcollins4
    kcollins4 Rocking somewhere
    5,732
    Katy, TX
    Very interesting thread! Thanks for posting.:thmbsp:
  19. 4-2-7
    25,787
    I found with my SP-5000s they were soft and mushy with my SS 85w pushing them. They're rated @ 90w, 102db, now with two MC275 MkVI mono bridged @ 180w tube power. Well lets just say they love it, they have long legs over the stated wattage. Much more responsive clear hard hitting bass with optimum tube power driving them. I did run them with one MC275 @ 90 WPC at first and they sounded very good but it was very easy to just bring the volume all the way up. I knew then I wanted to mono the 275 and the sp-5000 will handel it.
    moefuzz and NeedForSpeed like this.
  20. BLAH BLAH
    2,318
    Softisshh is the right word to describe my 5000s before I had them re-capped...
    Now a more silkier sound...smoother...easier...breathes well...the sound is seductively immersive..its like time slowsss down...
    Playing Sade now...she is singing in my ear as we dance...
    Athalwolf likes this.
