Scott 310E help
Discussion in 'Tube Audio' started by vendo81, Jan 6, 2019.
  1. vendo81
    vendo81 AK Subscriber Subscriber
    1,866
    California
    I bought a Scott amplifier and a Scott 310E tuner at a garage sale two weeks back. I got around to recapping the tuner this weekend and brought it up on a variac. I can hear a relay locking in as it tunes in a station but I'm only getting sound from one channel. The other channel has very low volume. I've read that the 2 relays should have the contacts cleaned and that one person had this same problem and the contacts corrected his. Thought I'd ask if anyone has cleaned the relay contacts on their Scott tuner and what they used?
  2. vendo81
    1,866
    California
    I should have mentioned that both channels are working in mono. Just one when switched to stereo. I'm sure it can be several things but I'd like to clean the relays.
    I'll be taking it to a friend to be aligned in a couple weeks but I'd like to get it going the best I can if possible before I leave it with him.
  3. century tek
    century tek Super Member
    3,569
    The Evergreen State
    If both channels work in mono then it is not an amplifier problem but rather a dirty switch. It may not be your problem, but clean all pots and controls with deox first and see what happens from there.
  4. radioactive
    radioactive tube gear fanatic Subscriber
    8,803
    winnipeg , manitoba
    Hope you get it figured out .the 310 e is suppose to be a real nice tuner.
  5. s-petersen
    s-petersen Scott Subscriber
    4,717
    Middletown,New York
    You would probably check for signal at c51 and C52 to see if the relay is the problem.
  6. vendo81
    1,866
    California
    Thanks for the help. I had cleaned all switches and controls with deoxit when I recapped the tuner but I did it once more to be sure. I got out my signal tracer and I do have a good stereo signal at the two .1uf caps (c51 & c52) so I need to clean the relay contacts. Looks like a couple screws each mounts them to the front of the chassis, and then maybe 4 screws on the bottom to remove the plastic cover.
    The tuner picks up an incredible amount of stations, very surprising. When tuned in the sound is clear but I'm getting a whistle type sound between stations, only at the lower end of the scale. I may leave this for my friend to look over when he aligns it as I just wanted to get it recapped and playing. Lucky for me the meter is working very well but it has that annoying bounce my 355 had until I put a cap across the meter. I'll have to do that. Had 2 good Telefunken 12au7's and one 12ax7 which was nice to find. Don't know if they are original as many of the other tubes are labeled Scott.
    The 310e, amp and one somewhat rough cabinet were buried in a VERY messy garage. Amp is a different style than the tuner so I may end up looking for an amplifier that matches if I like the tuner. Two of the small knob caps were missing and the others were loose and easy to pull off so I need to find matching ones and glue them all back on. Also, the round dial has a fine crack and it shows when lit up. I glued it from behind but I'll look for a replacement for that as well. I don't think that will be an easy find but I did noticed a couple of other Scott tuners from the same era have what looks like the same dial, so that may help. A friend told me he had heard a Scott 310e years ago and it was a great sounding tuner so I'm eager to get it working right and compare it to my 355's tuner. For now it will be used as is until I find what it needs.
    Lots of small problems, but they were inexpensive to purchase so I guess I shouldn't complain too much.
  7. radioactive
    8,803
    winnipeg , manitoba
    A 233 or similar will match it perfectly.
  8. kvflyer
    kvflyer AK Subscriber Subscriber
    3,201
    Fernandina Beach, FL, USA
    HH Scott 200B, 222D, 299D or LK-72B or should have the same style faceplate, what I refer to as the picture frame faceplate.
    radioactive likes this.
  9. vendo81
    1,866
    California
    Nice matching amplifiers! The 233 looks like a great amplifier and I really like the matching green lamps on the 299D.
  10. kvflyer
    3,201
    The 233 is quite rare. It is a bit lower in power than the 299C. It even came at the very end with 7868 output tubes instead of 7591 tube. You may have a hard time finding one. Also, the 233, while essentially a 299C has less "whistles and bells", some of which may be unnecessary. One more amplifier that will match the 310E is the LK-48B. I forgot to mention that one...
    vendo81 likes this.
  11. radioactive
    8,803
    winnipeg , manitoba
    The 233 is more in line with the lk 72b and uses the same opt. At one time I had a lk72( brown face) lk 72b and a 233.
  12. Dandy
    Dandy Super Member
    4,590
    North West, UK
    What model amp did you get?
  13. Patrice B
    Patrice B AK Subscriber Subscriber
    2,249
    Montréal, Canada
    Great score on what appears to be one of the best tube tuner of the era...
    vendo81 likes this.
  14. Selmerdave
    Selmerdave Well-Known Member
    825
    No affiliation but there's a 233 cheap on CL in New York these days...
    vendo81 likes this.
  15. vendo81
    1,866
    California
    It's a 222c. It has the faceplate style of my 355.
  16. vendo81
    1,866
    California
    I wonder what a nice 299D goes for? The 2 matching rectangular lights look great and it is listed as having 34 watts per channel.
  17. Dandy
    Dandy Super Member
    4,590
    North West, UK
    222C = 7189 tubes. 299D = 7591 tubes.
  18. vendo81
    1,866
    California
    Yes the 222c has 7189's. They can be a great sounding tube but I also like the 7591's. Most importantly I want it to match the 310E.
    Dandy likes this.
  19. kvflyer
    3,201
    Exactly correct. The 299 series "upgraded" if that is the term from 7189 outputs to 7591 outputs with the 299C. There are many slight variations in the various 299C model amplifiers, at least 7.
    222D has 7189 output tubes and the "picture frame" faceplate if that is important. And the 200B is a small lower power amplifier which has ECL86/6GW8 output tubes. I also failed to mention the kit version of the 200B; the LK-30B.
  20. vendo81
    1,866
    California
    Thank you. I'll be looking the different models up. I really like the 299D with it's 2 lights that match the 310e perfectly. They look like they were made for each other :)
