Scott LC-21 new pot and balance problem
Discussion in 'Tube Audio' started by Tenoates, Jun 11, 2018.
  1. Tenoates
    Tenoates New Member
    6
    hi,
    My LC-21 needed a new pot because it was becoming noisy with unbalanced outputs. I cleaned it a few times to no effect so I bought one off eBay from a seller who says his to be a drop-in replacement. The only differences from the original pot is this is a twist to turn on (rather than pull) and there are 5 taps (3+2) , instead of 4/ side on the original (3+1) . He told me to measure the 2 taps and use the ones that's were closest to the original.
    I installed the new pot using the notes I made before desoldering and confirmed the wiring on the original LC-21 assembly manual. Double checked everything and powered up.
    The first LP I played had good, clean, balanced sound but then the left channel turned off and I now only have sound coming from the right channel. If I move the balance to L, I get no sound except when I turn the pot to full. That's when sound comes out of the left channel.
    I double checked all the solders and connections again but everything seems to be correct. I swapped preamps to be sure it's not the amp and I confirmed it's the LC-21.
    What should I check to fix this?
    TIA!
  2. Patrice B
    Patrice B AK Subscriber Subscriber
    2,251
    Montréal, Canada
    Bad solder joint maybe? Re-check your wiring and make that there isn't any shorts.
  3. Tenoates
    Tenoates New Member
    6
    I checked for shorts yesterday and found none. I did measure the 22k and 220k resistors leading to the pot and they were lower than what they should be. I'll probably rewire it again once I get new resistors
  4. Patrice B
    2,251
    Montréal, Canada
    If I understand correctly: it was ok and then, left channel cut off? Maybe time do Deoxit...
  5. Tenoates
    Tenoates New Member
    6
    It's a new pot so I don't think cleaning will work.
    After I installed the new pot, both channels worked but after a while, there is no sound from the L channel but R channel has sound.
    If i turn the volume all the way up, the sound comes back to the L channel
  6. Dandy
    Dandy Super Member
    4,670
    North West, UK
    You don't mention the source and quality of the pot. eBay sellers offer variable quality products. Why not clean it with some switch cleaner anyway?
  7. gullaz
    gullaz Active Member
    165
    Bologna, Italia
    From what you describe it might be that one section of the new pot is defective. Check it with an ohmmeter on different wiper positions.
  8. Tenoates
    Tenoates New Member
    6
