uncooked
I just bought some cheaper banana plugs from acoustic research, i usually buy the monster ones that you insert the wire spread it around and twist the "nut" like back end back on until its tight and holds the wire in. "thoughs are the expensive ones" these ones http://monstercables.com/productPage.asp?pin=1272
BUT i just wanted to use some cheaper ones for the back of my receiver and got these, http://www.araccessories.com/Cultur...s;Speaker Wire;Banana Plugs&ProductDetail=YES
and i dont know how to use them..... they dont come with instructions, all it says is EASY INSTALLATION, NO CRIMPING OR SOLDERING NEEDED, SET SCREW DESIGN. Now since ive never used a "set screw designed banana plug i dont know how this works......"
someone mind helping me out here :sigh:
thanks alot
thanks alot
