Snommisbor
New Member
I am trying to set up a Zone B through my MX121 HT Preamp. Until I can get more amps to drive the speakers in other parts of the house I wanted to utilize my Rotel RX-1052 Stereo Receiver. I read in the MX121 manual that the Zone 2 requires analog signals so if I want to listen to a CD through my BluRay I need to add some RCA out of the Oppo103 to the L/R in of the BD connection of the MX121. I also have a Phono which is of course analog as well.
So I then ran an RCA cable out of the Analog Audio Out Zone 2 section (the bottom right of the MX121) to the audio in of the RX-1052 (I did CD first but have tried other inputs as well) I figured it would be getting the signal from the Zone 2 out section of the MX121 and wouldn't know that it was not a CD but just a signal and should work. I am not getting any signal coming out of the RX-1052.
Am I hooking something up wrong or is it not possible to power a Zone 2 through a Rotel Receiver? I attached rear panel drawings so you can see what I was doing and if there is something else I should try.
