Sherwood appreciation weekend
Discussion in 'Solid State' started by rkgren1, Apr 15, 2018.
  1. rkgren1
    rkgren1 Well-Known Member
    960
    Yorktown, VA
    I have my speakers in the living room system hooked up through an impedance matching switch that has a dual amp capability. Using a input selection switch connected in reverse, for the past few weeks I have been swapping receivers into the system, and comparing them to the refurbished Pioneer SX-950 that is the basis for that system. For each comparison both sets of tone controls are set flat and the volume knobs are set to equal intensity as best I can manage by ear. I alternately to Youtube music or a CD player. I was using Grafyx SP-8 speakers as my primary output. So far, I have compared the 950 to 3 Pioneers; a 636, a 1000TW, a Model 300, as well as an Onkyo TX-3000. I can easily distinguish between the 950 and the other units. They all have their differences, but the 950 always seems to carry the day on clarity and having enough low frequency authority to be called 'warm-sounding', an attribute that I like.
    This weekend I swapped in my Sherwood 7100-A. I generally refurbish equipment that I like, but this Sherwood happens to be untouched. It has apparently lived a charmed life, it was clean as a pin inside and out as I got it, and I have always liked its sound as-is.
    My conclusion after 3 days of comparing the two is that this particular S7100-A sounds exactly like the 950. The Sherwood obviously has way less (factor 6X) power. But the overall nature of its output at modest (plenty loud) power levels is identical to my ears to the 950. Same stomping bass, same clear midrange, and same detailed high frequencies. After toggling back and forth between the two many times, I often had to look at the switch positions to see which one is playing.
    I found this surprising. I expected the Sherwood to fall short on sound quality compared to a nearly as-new SX-950, given that it is 7 years older, and has had no maintenance. But it doesn't. The two receivers are twins with respect to how they drive these speakers.
    I have always said that this Sherwood receiver is 'as good as anything else in the house', and this weekend of A/B testing has proved it to me in a way that is far more convincing than walking between setups in different rooms. Within its limits the little Sherwood really is as good as my best receiver.
    edit: forgot the picture
    quiet likes this.
  2. Binkman
    6,345
    Chapel Hill, NC
  3. superdog
    superdog AK Member
    9,537
    Southern Colo.
    I have a s7100a that static electricity took out.Sweet sounding receiver.One of the few 70s receivers I kept out of many.
  4. Fleischer
    Fleischer Active Member
    336
    The S7100A is definitely one of my favourite receivers. Have one currently in my main listening room, replacing a Yamaha CA1010, and I am in no hurry to change the setup.
  5. LesE
    LesE 110284 Subscriber
    801
    Ontario, Canada
    Another enthusiastic vintage Sherwood owner here.
    Les.
    S-7100
    S-7200
    S-7300
  6. MER71
    MER71 Super Member
    That's why I run my Sherwood S8910 and kicked the MAC 1900 out of the setup.
    rkgren1 likes this.
  7. quiet
    quiet AK Subscriber Subscriber
    1,740
    arkansas
    The ability to test at will brings much to light in the would of vintage. The S8900a is taking on all challengers. So far.
  8. rkgren1
    960
    Yorktown, VA
    That's a nice family protrait.
  9. LesE
    801
    Ontario, Canada
    Hoping to add an S-7900 or S-8900 to the family some day. ;)
    quiet likes this.
  10. quiet
    1,740
    arkansas
    LesE
    I did. Only because the 7100a ran out of steam on the big dynamics. I figured if 20 was good 60 would be better.
    It is. Yes, get one.
  11. sberger
    sberger Hard Core Geezer Subscriber
    My primary receiver these days is a Fisher 500C, but it's nice to have a S8900A to swap in every so often, like tonight after reading this thread. Does a really nice job driving AR2 speakers. And the phono is excellent.
  12. VYNULADIKT
    VYNULADIKT AK Subscriber Subscriber
    224
    Northeast Iowa
    Thrift store find S-7050. Makes my office at work sound great with the ESS speakers it drives. Very nice little unit for less than $10
    IMG_1676.JPG .
  13. bobins08
    bobins08 AK Subscriber Subscriber
    5,964
    St. Louis, MO
    Great low power receivers. They sound like tube amps.
  14. LesE
    801
    Ontario, Canada
    This is especially true for the S-7100 with it's transformer coupled output transistors and capacitor coupled speaker connections.
  15. LesE
    801
    Ontario, Canada
    Right. I wasn't suggesting that the outputs were transformer coupled to the speakers. The output transistors are coupled to the previous stage using transformers as you mentioned. The output transistors are capacitor coupled to the speakers. I should have explained in greater detail.
  16. MER71
    MER71 Super Member
    I love my S8910. And my 14 year old son, has a S7210A
