Sherwood score and Dynaco SCA-35 vs Sherwood S5500IV
Discussion in 'Tube Audio' started by BSpaaudio, Oct 13, 2018.
  1. BSpaaudio
    BSpaaudio Active Member
    161
    Ballston Spa, NY
    So I scored three Sherwood pieces for $20.00 each. I've sold off the Sherwood S-1000 II amp and S-2000 tuner. But I may keep the S-5500IV amp.
    My question is, which amp has the better phono section, the Dynaco or the S5500IV?
    The problem with the S5500IV is that I suspect the volume on/off switch is shot which is why a previous owner drilled a hole in the face plate and installed a on/off push button. If I decide to revive the Sherwood I'll want to find a new face plate and volume on/off switch? What is the likely-hood of finding those parts, short of buying a second amp for parts?
    Thanks Sherwood.jpg Sherwood S5500IV (2) (1).jpg Sherwood S5500IV (2) (2).jpg Sherwood S5500IV (2).jpg
  2. Shadowdog
    Shadowdog Super Member
    2,999
    Flin Flon, Manitoba
    Sherwood from my reading the forums over several years, as Dynaco skimped in that area as it was a lower cost unit. The output transformers are nice though! Sherwood would have double the power output also with the bigger 7868 output tubes.
  3. vendo81
    vendo81 AK Subscriber Subscriber
    1,870
    California
    The 80 watt Sherwood integrated amplifiers are very nice. May take a while to find a donor with a decent face but you can listen to it while searching. I've never owned a SCA-35, but with half the power of the Sherwood, and knowing the quality of Sherwood pieces I'd keep the S5500IV for overall sound. As far as the phono section goes you need to hear from others who have owned the Dynaco.
  4. EastPoint
    4,820
    Milwaukee, WI
    You can buy a new complete volume control with power switch for the Sherwood on eBay, or possibly track down a replacement power switch.
  5. gadget73
    37,812
    Southern NJ
    I get that things break and sometimes a fix must be improvised, but why on earth do people make such ugly repairs? Would it have been that big a deal to lose the headphone socket or one of those slide switches that nobody ever uses to cleanly install a power switch? Ugh.
    Anyway, honestly they're both probably quite decent. If the SCA-35 uses the same phono section that the PAS does (honestly don't know this, but it would make sense if it did) the response should be very accurate. The PAS phono stage at least has been modeled and real-world tested to be a very close match to ideal RIAA, much as they claimed it was back in the 1960s. Not sure I've seen similar test data for a Sherwood, and I've never tested one myself but they do have a good sounding phono stage as long as you have decent tubes in there. Doesn't need to be anything special, but they can't be weak and it doesn't like a 5751 either.
    GuyNoir likes this.
  6. knockbill
    knockbill Addicted Member
    8,140
    SE PA
    +1,,, I've removed 2 prong AC outlets on the back of amps to add a switch,,, they are usually on the back, and are near AC line in, so would not move a hum source to a sensitive location... No need to ruin the face plate...
    Hell, a power strip would work with no damage!
  7. GuyNoir
    GuyNoir Confiderbunked Subscriber
    1,747
    Bismarck, ND
    Oh, the humanity and butchery. :no:
  8. gadget73
    37,812
    Southern NJ
    GuyNoir likes this.
  9. GuyNoir
    1,747
    Bismarck, ND
    Exactly!
