Hi everyone
please, i need your help with this one.
i will say first that i'm an amateur, but have basic knowledge and experience which i got mostly from you guys.
i just done cleaning and maintaining Sansui 6060 which was work absolutely fine.
as last step, i just wanted do to the Bias adjustment as described in the S.M
Mistakenly, while touching the resistors leads with the DMM probes, i also touched the chassis and then the two fuses got burned. (F603, F602) (250V, 5A)
1. While the fuses are off from the board, i turned on the receiver, it powered on, but the protection relay didn't "click".
I hope tomorrow i will find new fuses in the store,
but i really think that something went bad and the new fuses will auto-burned while i will turn the receiver ON.
I have a Dim Bulb Tester, i will use it. if i will find the receiver is shorted, which test can i make in order to find which components got died?
thanks
B.T.W is there any chance that nothing got damaged and if i'll put new fuses the receiver will play again?
thanks
