Shure Premier
Discussion in 'Turntables' started by Bugler, Sep 11, 2016.
  1. Bugler
    Bugler Super Member
    1,746
    Pittsburgh, PA
    I was looking on eBay for another headshell and found one with a Shure Premier cartridge with a new EVG 760-DED/Shure N75ED stylus. From what I could find on the web it appears that the Premier is simply a M75ED. Is that correct. Any opinions on this cartridge? I didn't need another cartridge but it was a really good deal. If nothing else it's good for testing used record purchases.
    Thx
  2. Joe Roberts
    Joe Roberts Agent Provocateur Subscriber
    1,168
    DC
    I have two of those with the yellow Shure ED stylus that came on old TTs I bought. Very enjoyable cartridge. I found I liked it more than I expected listening to old jazz records.
    I bought a few different aftermarket tips for it last week but haven't tried any yet. Surely local Shure specialists can offer guidance but the basic cartridge seems pretty good to me.
    Bugler likes this.
  3. spensar
    spensar New Member
    19
    Drugolf and Bugler like this.
  4. ETI_5000
    ETI_5000 Super Member
    2,862
    Hobart, Tasmania, Australia
    Yes, it's identical in all except name. I suspect Shure re-badged a bunch of older model cartridges to get rid of them, by giving them a name suggestive of top-quality.
    Quite good. In the early-70's the M75ED Type 2, and its twin the M91ED, which had the same performance, were equal second-best in Shure's line, behind the V15 Type II Improved. So with the original genuine Shure stylus, it had excellent trackability, and was one of the most reasonably-priced methods of improving the sound from many turntables. They also saw service as the official cartridges sold standard on many turntables around the world, including on brands like Dual, Garrard and Thorens.
    So they sound good, with a quite flat frequency response, track well (assuming a reasonable quality stylus), and styli are readily available.:thumbsup:
    Pio1980 and Bugler like this.
  5. Tenrag
    Tenrag New Member
    3
    I'm looking for a replacement stylus for a Shure premier cartridge. The old stylus is black, but I think it's a 3rd-party replacement, so I'd appreciate confirmation that it's an N75ed. Pictures attached. Thanks, Garnet Ward Shure premier 4.jpg Ward Shure premier 3.jpg Ward Shure premier 2.jpg
  6. marcmorin
    marcmorin AK Subscriber Subscriber
    9,264
    That is a Shure M75 cart. The best (available) Shure manufactured stylus that will fit on that is the Ne95ED stylus. It will look a bit different, being yellow in color, shaped a bit different........but it will play right up there with the N75ED type 2
  7. Tenrag
    Tenrag New Member
    3
    Thanks very much marcmorin. Are you suggesting that I shouldn't go for an after-market N75ed type?
  8. marcmorin
    9,264
    To get an aftermarket stylus to outperform the stylus I mentioned, you'll spend a good bit more. If trying to get by inexpensive, the EVG is decent enough, the Tonar branded, for a few dollars more is (imo/ime) a better stylus. The Jico is better yet, but then it's in similar money as the Ne95ED, and below the performance of it.
    Grbluen likes this.
  9. Tenrag
    Tenrag New Member
    3
    Thanks for your detailed explanation. It makes the decision much easier.
  10. marcmorin
    9,264
  11. aj_chicago
    aj_chicago Spin 'em if ya got 'em
    284
    California
    Well that is very interesting. A Shure Premier cartridge has always been a re-release of the M95 cartridge to me, and I have come to know that by everything I could read on the subject here on Audiokarma and on VinylEngine. I have a couple and they are definitely M95's. This one, labeled Premier, is definitely not an M95 from what I can see and compare. Can you tell an M75 from an M91 with no labels or anything else to identify them? I can't. Hmmmm. Larry (Mr. hackaplan), are you out there? Premier seems to be whatever Shure wanted it to be Premier at the moment. I wonder if these were just leftovers that were "obsolete" and that they wanted to rename so they wouldn't have to try to market an obsolete item with an obsolete name. I just received another Premier today, as a matter of fact. It is definitely the shape of an M95 and not an M75. It came with a light green stylus. Info in other posts here tells me that this is an M70EJ stylus, which was intended for an M75, but fits this Premier/M95.
  12. malden
    malden Addicted Member
    5,268
    I've seen both the M75 and M95 cartridge body types labeled as "Premier", and have one of each. There may have been a M91ED "Premier" version but don't recall ever seeing one. I'm not sure which styli offered with them but I would guess "nudies".
  13. Montycat
    Montycat AK Subscriber Subscriber
    17,598
    Vancouver
    I have a Premier M75 and I'm also pretty sure there is an M91 version. I have conclusive proof of the M95 connection, NIB and waiting for a rainy day.
    [​IMG]Shure M95 Premier Cartridge by Buhduh, on Flickr
    aj_chicago and malden like this.
  14. aj_chicago
    284
    California
    IS there any way to tell a "Premier" M75 from an M91 version?
    schon8624 likes this.
  15. marcmorin
    9,264
    the plastic body mounting is the difference between the 75 and 91, and of course, you can't put a 91 stylus into a 75 body, but you can put a 75 stylus into a 91 body
  16. tw1st
    tw1st Active Member
    231
    Toronto, Ontario
    My understanding of the Premier line is that they are in fact rebadged older cartridges (or perhaps re-released) and can be identified by the colour of the original stylus, i.e. Premier Yellow is actually an M95ED, etc.
    Now that doesn't help identify the bodies, and I'm not familiar enough with the M75 and M91 cartridges to tell them apart.
  17. aj_chicago
    284
    California
    You can put a 75 stylus into a 91 AND 95 body. Not sure about a 95 into a 75 body.
    So was my light green stylus (M70EJ I assume) not the original stylus on my M95 Premier body?
    From AK member in an older thread:
    Premier Yellow - M95ED
    Premier Black - M75ED Type 2
    Premier Light Green - M70EJ
    Premier Beige - M70B
  18. tw1st
    tw1st Active Member
    231
    Toronto, Ontario
    Disregard, my idea was already disproved above.
  19. malden
    5,268
    Three different versions of the Shure Premier
    1) same as the M75ED
    2) same as the M91ED
    3 Same as the M95ED
  20. aj_chicago
    284
    California
    Thanks! Pictures of the bellies would be worth 1000 words. :) I was looking at photos on google and I couldn't tell an M75 from an M91 if I didn't have something that spelled it out. Both seemed to have flat bellies/bottoms and the scalloped sides looked the same, too. I don't have an M75 (to my knowledge) to look at and my M91 is on something somewhere here. Know what I mean?
