Signal Relay Bad
Discussion in 'DIY' started by NeedForSpeed, Feb 8, 2018.
  1. NeedForSpeed
    NeedForSpeed Living In The Past Subscriber
    26,559
    SF Bay Area
    I have a Musical Fidelity Phono Pre amp, And it started a loud clicking. Opened it up, And one corner of the board gets very hot, And feel 2 relays vibrating more than the others. I found the relay on line, But a 20 week wait? There is a Panasonic hat I think is the substitute, But will that change the sound? Thanks in advance
    avionic likes this.
  2. Ray Gianelli
    Ray Gianelli AK Subscriber Subscriber
    1,174
    Lake Worth, FL
    From what you describe it sounds like whatever drives the relay is suspect. A bad relay shouldn't cause heat issues.
    Is the power supply ok? Correct voltages, no ripple? That's where I'd start looking.
    NeedForSpeed likes this.
  3. avionic
    avionic " Black Knights " Eagle Keeper Subscriber
    46,282
    Fort Dodge, Iowa
    If the relay works there should be no change in sound quality.
  4. avionic
    46,282
    Fort Dodge, Iowa
    Likely a relay driver pass transistor. Or regulated supply pass transistors. Are there heatsink mounted transistors on that corner of the board ?
  5. NeedForSpeed
    26,559
    SF Bay Area
    Thanks for reply, I have a pic. I pulled one reply that felt hot. Also, These are stick on, My first time with that style
    The lower left corner got very hot
  6. NeedForSpeed
    26,559
    SF Bay Area
    I use an external power supply, Pangea P-100. Seems okay
  7. avionic
    46,282
    Fort Dodge, Iowa
    Oh fun... SMT
  8. Ray Gianelli
    1,174
    Lake Worth, FL
    The external power supply may feed an internal power network, and if it's getting hot in that corner that may be the issue.
    As avionics pointed out SMT is a pain to work with. But it is doable if you have good tools and are careful.
    Check for shorts around where it's getting hot.
  9. gadget73
    37,708
    Southern NJ
    sounds more like the relay is being fed too much voltage, or its getting AC when it should be getting DC. Either way I'd agree that its probably not the relay so much as whatever controls it.
    Put the power supply on the scope, thats really the only way to tell if it has ripple problems.
